increasing the amp output on a factory 10SI alternator ??
Old November 9th, 2018, 06:41 AM
Bernhard's Avatar
Hi.
Has anyone increased the alternator output of their factory 10 SI GM alternator, using their original housing?
I see there are kits available to up the output from the aftermarket, has anyone used one?
Anyone use factory parts to increase the output?
Bernhard
Bernhard is offline
Old November 9th, 2018, 07:35 AM
Bernhard, is your stock alternator dead? If so, you could always replace it with a later model 10 SI alternator with a higher amp rating. If it's just one of those MAW projects then hopefully someone can give you some feedback on those kits.
Olds64 is online now
Old November 9th, 2018, 12:25 PM
Bernhard's Avatar
Berndard wrote:
The alternator works fine and is numbers correct
I just want to increase the output to ensure that the battery remains at near full capacity
The car is a project build and I will be going through the entire car
The alternator has to be able to keep up to a electric fuel pump and a UHV type of ignition system
Bernhard is offline
Old November 9th, 2018, 01:48 PM
Gary
VC455's Avatar
In my experience, the limiting factor in the 10SI frame is cooling capacity. If you limit the alternator to a range below 70 to 80 A, you won't exeed the cooling capacity. Otherwise overheating will shorten the life of the windings and electronic bits.
VC455 is online now
Old November 9th, 2018, 02:21 PM
stellar's Avatar
how many amps will your pump and ign be drawing?
stellar is offline
Old November 9th, 2018, 03:43 PM
442Fred's Avatar
PM sent
442Fred is offline
Old November 10th, 2018, 08:10 AM
Bernhard's Avatar
I don't have the pump or complete ignition system, I'm still souring parts for the ignition system. I did try to find the amp draw of the pump but have not found it listed on line yet.
The alternator will be running a under drive pulley as it will spend most of the time at the race track.
You are correct I should do a amp load calculation before sizing the alternator.
I forgot to include gauges, line lock , dash lights, dome light, headlights, wiper motor, maybe a data logger.
The car will be a a full delete car, No radio,No heater,no power windows, etc so the increase in amp load will be coming from the electric fuel pump and UHV ignition system.
Since I'm rebuilding the alternator anyway I would rather have some extra capacity to cover a possible increase in load.
Thanks for the reply
Bernhard
Bernhard is offline
Old November 10th, 2018, 09:41 AM
Out of Line, Everytime😉
olds 307 and 403's Avatar
100% true. I had a Chrome 10SI case rated at 100 amps, pretty sure output was more like 80 amps. Other than changing the voltage regulator once it gave 0 issues till the truck burnt to the ground from a shorted block heater cord. The other 10SI chrome alternator's that actually put out 100+ amps lasted maybe 5 years at the most. Why manufacturer's didn't copy the better 12SI fan and case must be they want the alternator's to last a short time. My BIL used a 94 amp upgrade on a 12SI case, lasted till he sold the car. Try it, just don't expect it to last for 20 years, 5 years will be pushing it in my experience.
olds 307 and 403 is online now
Old November 10th, 2018, 10:21 AM
stellar's Avatar
From your post I am guessing the alternator will have a large diameter pulley. This alone will reduce alt output especially at low RPM. If you want to use original alt cases, you will need to change the following parts (.Rectifier.) This should have diodes with 35 or 40 amp rating. 40 is better.( Regulator.) This should have a set point between 14.6 and 14.8. ( Stator.) This should be rated at 94 to 105 amps.( Rotor.) This should be rated at least 78 amp to 94 amp. 94 is better. The rotor is critical when using a higher output stator, especially for low RPM output. If you don't need to use the original cases, you should buy a stock 94 amp 12SI alt. It will bolt right up and probably cost less than changing your stock 10SI alt.
stellar is offline
Old November 10th, 2018, 03:28 PM
Bernhard's Avatar
I would like to use the stock housing as I would like it to appear completely stock.
I know most guys charge the battery between rounds because the cars don't have much run time and like you said with the larger pulley the charging rate is low.
I should have also mentioned that I will be using a factory starter and the comp ratio will be around 11.5 .
Are the stator and rotor from a GM AC / Delco 12SI or are they sourced from the aftermarket ?
Thanks again
Bernhard
Bernhard is offline
Old November 10th, 2018, 05:00 PM
Gary
VC455's Avatar
Originally Posted by Bernhard
The alternator will be running a under drive pulley...
Presumably this is to save horsepower. There are two things to consider in this regard.
1. Racers sometimes overestimate the amount of horsepower used by the alternator. At the most, let's say you need 50 A. At 14 V this is a 700 W output. This is less than one horsepower. Even if the alternator is only 80% efficient, that load would represent 1.2 horsepower.
2. Compare your standard 10SI with standard pulley to an enhanced 10SI with underdrive pulley. Let's say the standard 10SI with standard pulley would keep the battery charged under racing conditions. You want to slow down the alternator but raise it's maximum output so it, too, would keep the battery charged. If you succeed, both alternators would be putting out the same amperage and both would have the same horsepower consumption. You are spending money but not saving horsepower.
VC455 is online now
Old November 10th, 2018, 07:43 PM
stellar's Avatar
Thanks again
Bernhard
They can come from either OE 12SI or aftermarket.
stellar is offline
Old November 11th, 2018, 09:21 AM
Bernhard's Avatar
This is a very good point.
The reason I want to run the pulley is more about looks as a lot of racers back in the day ran the GM Chevy pulley.
Many guys were running a field on/off switch in Stock in the early 80's, that was not legal to run at the time looking for the 1 hp.
Their are many racers saying the 1hp gain could be a net loss if the fuel pump and ignition system were not delivering the performance needs of the engine.
Bernhard
Bernhard is offline
Old November 11th, 2018, 09:32 AM
Bernhard's Avatar
Thanks for the reply.
Are the 12 Si rotor and stator a direct bolt in or do they require modification to fit in the 10 Si housing?
Bernhard
Bernhard is offline
Old November 11th, 2018, 09:44 AM
stellar's Avatar
Direct bolt in. The regulator is also direct bolt in. The rectifier (diodes) are not.
stellar is offline
Old November 11th, 2018, 10:54 AM
Bernhard's Avatar
Thanks for the reply this is very helpful !
Bernhard is offline
Old December 3rd, 2020, 10:41 AM
MartinH's Avatar
Wow, lots of responses. Thanks.
Answers to some of the questions:
1. Alternator is not original as it is chromed. I cannot find any stamping on it indicating the amps.
2. Accessories: air conditioning, convertible hydraulic pump (stock). No power windows or seats. Can't think of much else that would draw much current.
3. I have dual 12" cooling fans that have "12V 120W" on each. My calcs show 20A total. I have a variable speed controller running them.
To be clear, the only time idle is an issue is when the cooling fans kick on.
MartinH is offline
Old December 3rd, 2020, 10:44 AM
MartinH's Avatar
Oops. Wrong thread. Sorry
MartinH is offline
Toocool
August 10th, 2018 12:33 PM
WendellB
April 20th, 2015 11:08 AM
87oldscutty
September 18th, 2013 08:38 AM
mmurphy77
September 5th, 2013 08:33 PM
442b
September 1st, 2011 12:00 PM
Quick Reply: increasing the amp output on a factory 10SI alternator ??
