'70 Cutlass Supreme Convertible W-31?????
Newbie here and to Cutlass. I just bought a '70 Cutlass Supreme Convertible project car in need of lots of restoration. It should be delivered to me on Sunday.
In a different post I had a couple of pictures of the engine casting numbers and Kenneth- Fun71 commented on the large oil pressure sending unit he saw in the picture and asked if it had the Ralley Pack Gauges
I went back yesterday to buy the car and took a closer look at the instrument panel. It definitely has gauges for the Oil Pressure and Water Temperature and not idiot lights and has a tach with the clock. Picture below.
The engine block casting numbers are 395558 which indicate it could be a W-31. I attached the Engine Block ID pdf.
Would having the Ralley Pack Gauges indicate that it has the W-31 option? What other reasons would someone add these special gauges to a Cutlass Supreme?
I haven't been able to find much info yet about what a W-31 means or how to determine if this Cutlass has that option.
Any info would be appreciated.
thanks,
Pat
thanks,
Pat
actually, my Supreme is a later 70 production with a qb engine which uses a cam from a 69 400. Spec on that cam is .472 lift, 286/286 duration and uses a unique carb, p/n7043253 which has larger jetting. This engine was only available with 4spd and 3:42 and higher gear ratio. I believe there were only about 500 of these engines built so it might be a little closer to a W31 then you originally thought
