Why so many different A-Body Export KPH speedometers?
Old October 6th, 2018, 07:24 PM
Alan Reedy
asx455's Avatar
Let me just throw this out here and see what anyone knows about this. I have pictures here of three different A-body speedometers, all export cars destined for different areas.
The first picture is a car destined for Canada with a speedometer that reads up to 200 KPH which roughly equates to about 120 MPH.
The second picture is a car in Germany (that I imagine was shipped through the Bienne GM Facility in Switzerland) which has a 240 KPM speedometer which roughly equates to about 150 MPH.
The third picture is a car that was definitely shipped through the Bienne GM Facility in Switzerland, for a customer in France, which has a 270 KPH speedometer, which roughly equates to 165 MPH.
Does anybody have any input on why there are so many variables?
asx455 is offline
Old October 6th, 2018, 07:52 PM
I dunno, but it would be cool to get a 200 KPH speedo and set it up for for MPH.
Fun71 is offline
Old October 6th, 2018, 11:25 PM
hurst68olds's Avatar
year would matter as would manufacturer AC Delco or other & CANADA didn't go metric 'til '75 or '76?
hurst68olds is offline
Old October 6th, 2018, 11:37 PM
svnt442's Avatar
Well the first pic looks to be in a 1970 due to the burlwood dash. The second I would guess is a 73-75. And the third is a 71-72.
My question is why is the 60 orange on the last one? That's roughly 37 MPH or so...an odd speed to highlight.
svnt442 is offline
Old October 7th, 2018, 02:26 AM
Rustbucket2's Avatar
I like the first one. has two indicators. and has a **** on it, is that to set a warning buzzer for a certain speed?
Rustbucket2 is offline
Old October 7th, 2018, 06:46 AM
All you have to do is change the speedo drive/driven gears in the trans.
Of course, the bigger question is, why? To impress the uneducated? Kind of worthless to have a gauge where you can only use half the sweep. All that means is that the resolution is worse at the speeds that you drive at. This is Instrumentation 101. I frankly have this problem with aftermarket tachs. Why should I buy a tach with 0-9000 or 0-10000 sweep when I rarely need more than 5000 RPM? I wanted a nice tach for my engine run stand, but I'm not running the engine over 2500 RPM during cam break-in. A nine grand tach is worthless, especially since many new ones now have a non-linear scale that has less resolution at lower RPMs.
joe_padavano is online now
Old October 7th, 2018, 09:52 AM
Alan Reedy
asx455's Avatar
The third one is an early built 71 442 with a date of 9A on the data plate. Still has some 70 parts like flat top fenders and water neck.
asx455 is offline
Old October 7th, 2018, 11:37 AM
I remember this one. Canada road speeds didn't go metric till around 1976\7 and when the highway speed signs changed from 60 mph to 100 km/hr (which is actually faster) etc GM put a big push onto the dealers to sell the speedometer conversions. They basically were a vinyl overlay that went over top of the existing speedometer. To see one here now is relatively rare, and obviously not as issued by the factory. I remember my Dad buying a 76 Malibu Classic and the speedo was still MPH but had KM/HR in blue numbers under the MPH
Allan R is offline
Old October 7th, 2018, 11:52 AM
Alan Reedy
asx455's Avatar
That first one is the only one that makes sense to me. Changing the numbers to where the indicator already is in MPH would seem like the easiest way. I don't know why the others are extended so far out to measure that area of top speed.
asx455 is offline
Old October 7th, 2018, 12:28 PM
oldspackrat's Avatar
The middle picture in the first post is of a 1970 442 speedometer and this is the before restoration picture. It looked much better when I was done.
oldspackrat is offline
Old October 7th, 2018, 12:31 PM
I can see the German speedo being what it is likely due to legislation for a metric speedo. Since their autobahn allows for insane speeds in some sections but on average it only allows 130 km/hr, but the one for 270 doesn't make any sense. It looks to me more like someone created a sticker and colored in that 60 KM/HR.
I googled French speed limits and they mimic Germany very closely so the need for 270 isn't practical. Another thing to ponder is how would anyone expect a 1970-72 Cutlass to ever achieve those speed limits??? BTW, I find that 1970 speedo with the speedminder set at 155 kind of ridiculous. If you're going that fast, you'd know it because you'd be doing close to 100 mph and the engine would definitely be telling you that and the fuel gauge would likely be easy to see as a steady movement towards empty.
Allan R is offline
Old October 7th, 2018, 12:32 PM
Pic??
Allan R is offline
Old October 7th, 2018, 02:26 PM
Alan Reedy
asx455's Avatar
The second one after being restored.
asx455 is offline
Old October 7th, 2018, 03:05 PM
Looks good but still speeds are over rated IMO. 240 Km/hr = 150 mph which I seriously doubt any stock Cutlass will do.
Nice job on the restoration Scott. What would be really cool is to find the stickers for the 1/10's mph and make them crisp and white again.
Allan R is offline
Old October 7th, 2018, 03:46 PM
svnt442's Avatar
Well....I had a 1980 cutlass up to roughly 142 mph (calculated). That was with a completely stock 1975 350 and a 2.28 rear end. The engine was turning about 4250 rpm. At 100 mph it was turning 3000 rpm.
So if you had a cutlass with a 455 and 2.56 gears, I think it would easily do 150 mph. Would it be stable? Most likely not, but it could do it.
svnt442 is offline
Old October 8th, 2018, 03:38 AM
'87 Delta 88 Royale
rustyroger's Avatar
I doubt it. The drag coefficient increases at the square of the speed, without doing the math I suspect you would need in the region of 500bhp to move a Cutlass of that vintage through a 150 mph headwind....
Roger.
rustyroger is offline
Old October 8th, 2018, 03:42 AM
'87 Delta 88 Royale
rustyroger's Avatar
Not really an odd speed. 35mph is a common speed limit in the USA. But then 55mph might seem odd in European eyes.....
Roger.
Old October 8th, 2018, 08:38 AM
Yes, that is the Safety Sentinel Speedometer, U15, I think. Set the white needle where you want, and there is a spring contact on it that follows along. When the speedo needle sweeps by, the spring will get rotated and send power to a buzzer on the printed circuit which will sound until you either drop speed or adjust it higher.
Koda is online now
Old October 8th, 2018, 04:03 PM
svnt442's Avatar
Roger.
how much less aerodynamic do you think a 70 would be over an 80? Respectfully I disagree with you due to my personal experience.
I had a 455 in a 70 with 2.56 gears an I have no doubt that it would have done 150. I never tried because the suspension needed a ton of work to be safe at high speeds.
svnt442 is offline
Old October 8th, 2018, 04:51 PM
I never tried...
So your estimate of 150 is based on what, exactly? Your butt dyno?
Sorry, but not very compelling proof.
I had a 68 Vista with a transplanted 425 and 2.73 gears. It maxed out at 121 indicated. The aerodynamic drag force is about 50% greater at 150.
Old October 8th, 2018, 05:36 PM
Thanks Allan,
The numbers & letters are silk screened? or lightly painted on the face of the speedo, Any vigorous attempts to wipe dirt or rub dust off of them will remove the white paint. This one had small rust specks all over the face & I had to do some thinkin' to get it clean but it did turn out as nice as it could be.
Old October 8th, 2018, 05:51 PM
oldolds88's Avatar
the end one on the right one with the orange on it,looks to be some sort of back flash image from the camera,look close and you can see the guy taking the picture. orange shirt maybe?
oldolds88 is online now
Old October 8th, 2018, 07:49 PM
svnt442's Avatar
I did go past 120 in the 70...once and it had plenty left in it.
I would bet that it was actually more aerodynamic than my 80 was due to the rear glass design and I was able to reach about 142 with the 80.
I would be very shocked if the 70 wouldn't do that with 250+ more horsepower and gobs more torque.
svnt442 is offline
Old October 9th, 2018, 11:06 AM
Alan Reedy
asx455's Avatar
I hear what you're saying but that is not the case here. That speedometer clearly has that # "60" and its "marker" marked in Red for a reason. Whatever the reason is, is beyond my guessing ability. I still don't understand why there are three different ones in almost the same year.
asx455 is offline
Old October 9th, 2018, 01:19 PM
anthonyP's Avatar
A 1971 W-30 supposedly purchased new by someone at U.S. Embassy in England. It has a 200 KPH speedometer.
https://classicoldsmobile.com/forums/general-discussion/34434-1971-442-w30-export-model-england-uk.html#&gid=1&pid=2
anthonyP is offline
Old October 9th, 2018, 02:10 PM
Seff's Avatar
I have the same 200 KPH speedo as the thread starter has in the first picture, and as the US embassy car has in the post above mine. The speedo came out of a 71 Supreme from Holland. I have the import tag from the inner fender somewhere.
Seff is offline
Old October 9th, 2018, 02:11 PM
'87 Delta 88 Royale
rustyroger's Avatar
https://classicoldsmobile.com/forums...l#&gid=1&pid=2
But we still use miles here. Could be he intended to use it in Europe, or maybe export cars all had kph speedometers?.
Roger.
Old October 9th, 2018, 02:57 PM
Alan Reedy
asx455's Avatar
Does your import tag look something like this?
asx455 is offline
Old October 9th, 2018, 09:19 PM
Seff's Avatar
It looks exactly like that. Does it mean that it was sold by a dealer in the EU?
Seff is offline
Old October 10th, 2018, 02:11 AM
Levellord's Avatar
Well, quiete easy. The car was made for french market, at this time the speed limit in the city in France was 60 km/h.
It was reduced to 50 km/h somewhere in the 80´s.
Levellord is offline
Old October 10th, 2018, 11:00 AM
  #31
Alan Reedy
asx455's Avatar
The short answer to your question is Yes. It sold new through a dealer somewhere over there.
That tag is a VIN / Body Tag, affixed to the vehicle indicating it's overseas life originated from the Suisse S.A. General Motors Assembly Plant in Switzerland. I am unaware of the actual level of processing (if any), it has gone through in that assembly plant due to the fact that the car was manufactured in Lansing for export. It may have well been just a safety inspection to check for conformance with foreign safety requirements. I would like to see a picture of the cowl tag on the car that has this VIN plate affixed to it.
asx455 is offline
Old October 10th, 2018, 11:14 AM
  #32
Seff's Avatar
Here's a few pictures. '71 350/350 Supreme non-AC car, rear defog (the wires in the rear window, not the blower motor), power windows and four-way electric seat. FE-2 suspension.
Seff is offline
Old October 10th, 2018, 01:09 PM
  #33
Alan Reedy
asx455's Avatar
Is it possible for you to show a picture of the body tag located on the firewall near the windshield? The tag I showed was very similarly optioned, Non AC, wired rear defroster, power windows and 4 way bucket seat.
asx455 is offline
Old October 10th, 2018, 01:14 PM
  #34
Seff's Avatar
Nope, the car is gone, and I don't have a picture of the body tag.
Seff is offline
Old October 13th, 2018, 05:35 AM
  #35
Out of Line, Everytime😉
olds 307 and 403's Avatar
Interesting to know the conversion speedometer exists. As said 76/77 is when we switched, our old 75 Cutlass growing up was mph, as is my 70S. Most of the cars we owned were dual, usually Km/hr on top and mph on the bottom. I have to remind the kids my car is in mph, a speedo conversion would be handy.
olds 307 and 403 is online now
Old October 13th, 2018, 08:48 AM
  #36
anthonyP's Avatar
The third photo seems to be from the 1971 442 that was exported to Germany. Cannot find an interior photo of the 1971 442 that was exported to Lebanon.
anthonyP is offline
Old October 13th, 2018, 10:44 AM
  #37
Rocket Renegade!
No, you didn't. Not calculated, not observed, not no-how. Not with that engine and drivetrain in that body.
NO!
BangScreech4-4-2 is online now
Old October 13th, 2018, 01:28 PM
  #38
Alan Reedy
asx455's Avatar
Yes Anthony, this is the same car. It is currently being shipped back to Switzerland for the second time.
asx455 is offline
Old October 13th, 2018, 02:27 PM
  #39
anthonyP's Avatar
Seems the export cars noted in the thread have the same options.
anthonyP is offline
Old October 14th, 2018, 01:58 AM
  #40
svnt442's Avatar
NO!
Ok...you do the math...27" tire, 2.28 gear, 4250 RPM. It happened whether you believe it or not.
svnt442 is offline
Quick Reply: Why so many different A-Body Export KPH speedometers?
