Box of stuff, previous owner
Received this box of stuff from the previous owner. Inside was this distributer marked CARDONE REMANUFACTURED. One, is it a 350 Oldsmobile distributer?? I have nothing to go by because the current one has an HEI in it. This one looks quite a bit shorter than the HEI. All you wonderful pro's out there help me out is this a Olds 350 distributer and the brand good, bad, no difference as long as it works? Opinions please. Of note, the camshaft gear shadt is 6 sided as shown in the third pic.
Hard to tell if it's a "350" distributor without looking up the number stamped on the body and correlating that to the original application.
An Oldsmobile distributor will basically fit into any second generation Oldsmobile engine - 260, 307, 330, 350, 400, 403, 425, 455.
In your first picture there's a number stamped onto the side of the distributor housing - starts with 1111 but can't make out the rest. Post that and I'll see if it's in the parts manual.
