Convertible top pump
Old September 16th, 2018, 10:10 AM
Bfg
Bfg's Avatar
I'm getting ready to raise the top on my 65, the car has been sitting inside for many years. All the hoses are intact and no signs of any leaks. I'm going to open the pump and check the fluid level before I try to raise it. Is it nessisary to flush the system or just top off if it needs to be? Any other recommendation?
Bfg is offline
Old September 16th, 2018, 10:38 AM
Proud Viet Nam Veteran
redoldsman's Avatar
You should be able to top it off. Be sure and use ATF and not brake fluid. Brake fluid eats paint. Get several rags to put under the pump because this is a nasty job. I have the smell of ATF. Good luck.
redoldsman is online now
Old September 16th, 2018, 11:27 AM
Bfg
Bfg's Avatar
The service manual says top off with hydraulic brake fluid. I would prefer to use ATF like you suggested. If it originally was filled with brake fluid will ATF be compatible with brake fluid? Or will I have to flush the brake fluid?
Bfg is offline
Old September 16th, 2018, 11:28 AM
WHICH service manual?
Koda is online now
Old September 16th, 2018, 11:56 AM
Bfg
Bfg's Avatar
Stated in the 1965 Oldsmobile Body Service Manual.
Bfg is offline
Old September 16th, 2018, 01:24 PM
I would try it as-is and see how it works first.
Fun71 is online now
Old September 16th, 2018, 01:28 PM
Older Lincoln convertibles used brake fluid in the top pump. Since brake fluid is not optimal around painted surfaces a popular mod is to replace it with ATF. Several of the Lincoln people have said in order to do this you must flush all the brake fluid out first. ATF and brake fluid wouldn't mix in the brake system, so I'm guessing it wouldn't do too well in the pump.
slantflat is offline
Old September 16th, 2018, 03:50 PM
Bfg
Bfg's Avatar
I think I will try to raise it and see what happens after I check the fluid level. I have already unbolted the rods that attach to the frame to raise it manually and see if it raises without binding and also to lube the pivot points.
Bfg is offline
Old September 16th, 2018, 03:51 PM
Tedd Thompson's Avatar
You will be able to tell with one sniff of the fluid which it is. In the last 50 years I don't think any manufacture has used break fluid but occasionally it does show up. My convertible pump and cylinders had brake fluid in them when I started my restoration. All of the cylinders and pump parts had absorbed moisture at sometime and destroyed the working parts, peeling paint wasn't the problem but rust sure was..... Tedd
Tedd Thompson is offline
Bitburger
June 20th, 2019 08:20 AM
2oldsguy
September 18th, 2018 07:08 AM
805cut
Brakes/Hydraulic Systems
September 25th, 2012 01:59 PM
Bunser
September 29th, 2009 05:20 AM
cfair
June 8th, 2009 12:37 AM
Quick Reply: Convertible top pump
