HELP Please: Brake Booster Rod Length?
Old September 13th, 2018, 02:39 PM
Kensey's Avatar
Hi all.
So I'm changing out the master cylinder on my 72 Delta 88. The booster seems fine, so I cheaped out and decided to just do the master c. This is probably where I f-ed up...
My new master cylinder looks to be the same, minus bleeder valves at the line connectors. (Never saw that before) However I discovered that the booster push rod is about 1.5 - 2 inches too long. There's not enough threads on the rod to adjust it in.
Any suggestions on what to do? I'm thinking a new booster is probably the smart way to go?
Thoughts? Thanks!
Kensey is offline
Old September 13th, 2018, 03:36 PM
66luvr's Avatar
You just got the wrong master cylinder for your booster, probably not your fault.
According to Auto Zone, a 72 88 with a Delco Moraine booster takes a shallow hole in the master cylinder.
If it has a Bendix booster it takes a deep hole in the master cylinder.
Given that information I think you may have a Bendix booster and need a master cylinder for that application. Auto zone number NM1496 is their new unit--- and a reman unit is # M1496, these have the deep hole you need.
I would switch the master cylinder and keep the booster.
Good luck,
66luvr is online now
Old September 13th, 2018, 03:51 PM
Kensey's Avatar
Devils advocate here... Could I just buy the correct power booster for the master cylinder that I already bought? Then I'd be new/new.
Confession: I adjusted the push rod all the way in and didn't mark where it was. Yes, I'm an as*hole.
Thoughts???
And THANKS 66lvr
Kensey is offline
Old September 13th, 2018, 04:31 PM
Gerald Nickels's Avatar
Get the right master cylinder.
Gerald Nickels is offline
Old September 13th, 2018, 04:39 PM
Kensey's Avatar
Totally get your point! But my question is, since BOTH styles are listed as correct replacements, can I switch over? Will it bolt up and operate fine. The only difference seems to be the push rod length. And each style has a matching booster.
Kensey is offline
Old September 13th, 2018, 04:54 PM
Most kits come with two push rods look in the box.
Old September 13th, 2018, 05:03 PM
Gary
Gary's 2 442-S's Avatar
If my understanding your problem is the push rod between the booster and master cylinder then there are two different lengths on the push rod.
https://www.ebay.com/itm/67-72-A-F-X...sAAOSw7t5aoY5t
Gary's 2 442-S is offline
Old September 13th, 2018, 08:39 PM
edzolz's Avatar
Your master should have came with a "bullet" that takes up the space the non booster cylinder is made for. It fits inside the end where you show the screwdriver is inserted.
edzolz is offline
Old September 14th, 2018, 04:53 AM
Kensey's Avatar
Slept on it. Decided to do the correct thing and ordered the correct parts.
Thanks all!
Kensey is offline
Fastmax32168
Brakes/Hydraulic Systems
September 1st, 2018 01:34 PM
Rustbucket2
March 11th, 2016 07:11 AM
NigelH88
September 26th, 2015 11:09 AM
bluecab
April 15th, 2015 05:27 AM
STLCRZY
March 10th, 2014 07:36 AM
Quick Reply: HELP Please: Brake Booster Rod Length?
