Can any tell me what this is please
That is exactly what it is, used in early 60s Oldsmobiles for most high power accessories. Power top, power windows, power seat, power rear window in a wagon, etc.
X2 on that !
It looks like one of the wires was very hot . This was due to very high resistance at the terminal or inside the relay.
My suggestion would be to replace the relay , And re-do all the "funky" connectors .
You can get one here ;
http://www.fusickautomotiveproducts....number=4849847
The obvious problem with the OP's circuit breaker is that the wires with the yellow and red crimp fittings are not factory. What do those go to? Has this unit been overloaded? Are these cheezy aftermarket crimp fittings corroded (good bet) thus causing the heating?
X2 on that !
X2 on that !
https://www.rockauto.com/en/tools/el...reaker,1001328
On my 67 Cutlass Convertible it is located on the firewall low and outboard of the brake master cylinder. The corroded bolt, nut, and burnt wiring suggests that it got very hot at some time in the past. The cloth insulated wire looks like the feed wire but the other one is an aftermarket add-on which means the melted red wire is not fused unless the the factory wire is a fusible link! Maybe a stereo amplifier from back in the '80s? Find the reason for the overheated wire and either remove it or replace the wire after repairing the reason for the short that caused the overheating problem.
Found a photo of the same part on my 67. This is what the relay looks like dirty and unmolested, probably since new. I was right that the cloth insulated wire is the feed wire that is connected to the horn relay post. It is not a fusible link so it will provide power until it burns up if shorted to ground. It is located below and outboard of the wiper motor as seen in the upper left of the photo.
