403 flexplates
Old September 6th, 2018, 12:47 PM
Oldsdruid
rocketraider's Avatar
403 flexplates
Bud has a 77 LeSabre Estate Wagon w/ 403 that is having to have it's 2nd flexplate in 10 years. It developed a knock that sounded just like a rod knock so he had it towed, and the mechanic found the "new" flexplate cracked almost out to the ring gear.
Car did this about ten years back and that one sounded just like a weak lifter.
Apparently all you can get now are Chinesium replacements. Anyone else having 403 flexplate issues?
rocketraider is offline
Old September 6th, 2018, 01:05 PM
When I've had cracked flexplates, it was always due to misalignment problems between the block and trans case. In particular, I had one situation where the bolts has loosened up, causing the flexplate to, er, flex. That led to cracking. I'd get the shop to ensure the trans input shaft is concentric to the crank, and that the bellhousing bolts are properly torqued. Be sure that there isn't a problem with debris or burrs or casting flash on the bellhousing mating faces or dowel pins.
joe_padavano is offline
Old September 8th, 2018, 05:13 PM
BillK's Avatar
What Joe said and also make sure there isn't a lot of end play in the crankshaft. I would think that this would give other symptoms also but on a seldom drive car maybe not ? And make sure that you can pull the converter back from the flexplate 1/8" or so when it is unbolted.
BillK is offline
Old September 8th, 2018, 06:30 PM
oddball's Avatar
Note that the 403 uses the typical later Olds pattern so you can also just look for a flexplate for any 350 or 455. There are a handful of aftermarket and SFI certified ones.
As mentioned, breaking two flexplates is really strange.
oddball is offline
Old September 25th, 2018, 02:36 PM
jackolds403's Avatar
Do you know if there are compatible flywheel for the 403olds?
I will mount muncie on this engine, but need a right flywheel...
jackolds403 is offline
Old September 25th, 2018, 02:44 PM
As mentioned above, all 1968-1990 Olds motors take the same flywheel or flexplate. Any flywheel that fits a 350 or 455 also fits a 403.
Old September 25th, 2018, 02:45 PM
Sounds good!
Old September 25th, 2018, 05:17 PM
Has the transmission been overhauled before? It’s rare, but maybe the converter was rebuilt and wasn’t welded straight? Does the converter pilot hub fit snug in the crank? Sounds like something is causing the flexplate to flex excessively
matt69olds is offline
Old September 25th, 2018, 05:32 PM
My money is on missing dowel pins.
Koda is offline
Tubescatgs
November 20th, 2013 08:45 PM
halfmoontrail
May 31st, 2013 05:41 AM
330oldsmobile
January 2nd, 2011 05:45 PM
PetChemMan
August 10th, 2008 10:52 AM
falconsfan
June 1st, 2007 08:05 PM
Quick Reply: 403 flexplates
