Electric Choke Conversion Kit
Old August 14th, 2018, 04:43 AM
Apollo's Avatar
Hello,
Researching an electric choke for my 1972 CS 350 4BBL. Seems like some of you folks have done this. What kit did you use and were you happy with the results?
Any comments or suggestions would be appreciated.
BTW, I found Joe's post about wiring for the EC , slick, I bookmarked that !!
Apollo is offline
Old August 14th, 2018, 06:00 AM
If you have a stock Qjet, you don't need a kit. Simply replace the hot air choke coil with an electric one. I use the ones from a mid-80s Chevy Qjet. Standard Motor Products P/N CV329, about $38 at RockAuto. Note that the terminal requires a special plug to fit. Dorman P/N 85113 is about $4 at RockAuto. Be sure to discard the gasket between the old choke thermostat and the housing. The electric thermostat requires metal-to-metal contact for the ground path.
joe_padavano is online now
Old August 14th, 2018, 09:57 AM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
And be sure the 12 VDC wire is connected to a keyed 12 volt source so it shuts off with the engine.
droldsmorland is offline
Old August 14th, 2018, 10:59 AM
Well, technically, you want the choke connected to a source that only has power when the engine is running. This is why I showed the use of an oil pressure switch, which is what the factory uses. If you have an oil pressure switch, it doesn't matter if the source is keyed or full time, since the switch only closes when there is oil pressure.
Old August 14th, 2018, 07:10 PM
Good point Sir.
Old August 15th, 2018, 07:21 PM
vmathy's Avatar
Use Joe P's oil pressure switch setup, works perfect!
vmathy is offline
Old February 3rd, 2020, 07:07 AM
HurstOlds79
walkerkj's Avatar
I see the part numbers for the oil pressure switch. My car has an oil pressure gauge in addition to an idiot light. Will any of these switches support the three circuits? Oil pressure gauge, oil pressure light and electric choke?
Thank you
Kevin Walker
walkerkj is offline
Old February 3rd, 2020, 07:24 AM
yellowone's Avatar
Joe, what info do you have for a 2bbl carb?
yellowone is offline
Old February 3rd, 2020, 08:04 AM
Thank you
Kevin Walker
I'm not aware of a three way sender like that, and frankly, every gauge requires a different resistance range for the sender. Just install a tee fitting with the sender for the gauge and the sender for the idiot light and choke.
Old February 3rd, 2020, 08:06 AM
If you're talking about a 2GC, the coil in the choke operates in the other direction. There is an electric choke coil that works in this application. This thread will provide more info.
Old February 3rd, 2020, 08:11 AM
HurstOlds79
walkerkj's Avatar
Thank you for your response. Are you referring to a pneumatic tee or a jumper wire? If a pneumatic tee, would you happen to have a part number I could order? I would not know where to begin.
walkerkj is offline
Old February 3rd, 2020, 08:15 AM
I'm talking about a 1/8 NPT brass tee fitting.
Old February 3rd, 2020, 12:28 PM
oldsmobuser's Avatar
Apollo, I hooked mine to a 12 volt source that is on when the key is on. That was in 1992. Have never had a problem. I see this is an old thread and you may have already figured it out. Take care.
oldsmobuser is offline
Old February 3rd, 2020, 01:44 PM
Schurkey's Avatar
Given a choice, I route the power from a source that's hot with the key in "Run", but not hot in "Accessory", "Off", or "Crank". I don't want the choke powered while the starter motor is grinding away; extended crank time in the winter shouldn't open the choke.
THEN route the power through a normally-open oil pressure switch, so that the choke won't continue to heat if the engine stalls while I'm inside having my last cuppa coffee while the engine warms-up.
Schurkey is offline
Old February 3rd, 2020, 03:04 PM
Which is what this sticky from 2011 shows.
joe_padavano
Tech Editor's Desk
97
April 6th, 2023 11:14 AM
Chuck Cole
July 9th, 2019 09:38 PM
bundy
November 1st, 2014 05:56 PM
Al Sanchez
March 5th, 2013 04:49 PM
bobfo1
November 25th, 2012 10:37 PM
Quick Reply: Electric Choke Conversion Kit
