Battery cable mount location
Old July 16th, 2018, 11:21 AM
jesse.havlik's Avatar
I have a 1969 Oldsmobile Cutlass with a 455 in it. I would like to know where the stock location of where to mount the negative battery cable to? I cannot seem to find this anywhere.
jesse.havlik is offline
Old July 16th, 2018, 12:31 PM
Randy C.
rcorrigan5's Avatar
Check your 1969 Cutlass/4-4-2 assembly manual, manual section 12, page 131. It shows routing with or without A/C. If you don't have an assembly manual for your car, I highly recommend obtaining one. They are easily available through ebay and a wealth of information at your fingertips.
Randy C.
rcorrigan5 is offline
Old July 16th, 2018, 12:38 PM
72 Olds CS
RetroRanger's Avatar
to the engine block behind the PS pump.
also ground from the pass side head to the firewall w braid strap
RetroRanger is offline
Old July 17th, 2018, 06:13 AM
I have the assembly manual on its way. Thanks for the reply. Just to make sure I fully understand, you are referring to using one of the bolts that holds the power steering pump to the engine block?
Old July 17th, 2018, 01:20 PM
Hookers under Hood
76olds's Avatar
No, don't use any of the P/S bolt holes or P/S bracket holes.
See the bolt in behind the pump with the silver ground cable end with black negative batt cable going to it.
See photo attached below,
Hope this helps,
Eric
76olds is offline
Old July 17th, 2018, 02:23 PM
72 Olds CS
i was mistaken looks like its the drivers side head it bolts too....heres another view
Old July 17th, 2018, 03:33 PM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
It is a shallow hole too so you will need the correct bolt and star washer to be correct. The black bolts in the Fusick link are what I am referring to. Make sure all your grounds are clean and tight. Factory hardware goes a long way to ensuring factory spec grounds. Clean your positives too at the battery and at the starter. Same for the alternator connections. Clean connections = less resistance = less heat = a happy car.
http://www.fusickautomotiveproducts....?dept=76&val=5
droldsmorland is offline
Old July 18th, 2018, 06:41 AM
Thanks for all the great facts here. I'm glad I joined this group. I will need all the help I can get as I have never owned a Oldsmobile before. Thanks again.
Old July 18th, 2018, 04:50 PM
Hookers under Hood
76olds's Avatar
Welcome to CO Jesse,
Don't hesitate to ask any questions here, so many guys here to help. A Chassis Service Manual will certainly come in handy for doing the actual job once your questions have been answered.
Cruzn 66 always has nice manuals for sale here , you could PM him and ask if he has any available when your ready.
I keep my manual on my fender when quick reference while working on most area's of my car.
Cheers
Eric
76olds is offline
Richard Miller
August 27th, 2019 02:31 PM
68Tom
May 12th, 2019 11:19 AM
rothlane'68
August 1st, 2017 06:17 PM
The Bug Man
February 3rd, 2016 03:00 PM
W31driver
October 30th, 2012 04:40 PM
Quick Reply: Battery cable mount location
