Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
dropping a 468 in my cutlass
Old June 20th, 2018, 09:59 PM
Glover117's Avatar
I have a 1972 cutlass S and Im taking out my Oldsmobile motor and dropping a chevy 468 in it and I was just wondering which motor mounts I need? can I use the Oldsmobile mounts or do I need a different kind? if so which mounts do I need?
Glover117 is offline
Old June 21st, 2018, 03:20 AM
Welcome to the site. You need to treat it like a Chevelle, use Chevy engine mounts and frame brackets. You also will need to run an adapter plate or a non-bop transmission. Starter wiring needs to be moved to the other side and possibly other accessories may need to be rerouted.
Here is an engine mount/ frame bracket kit:
https://www.ss396.com/chevelle/ACE-9794KIT.html
oldcutlass is online now
Old June 21st, 2018, 07:26 AM
garys 68&72's Avatar
Good news, my 72 frame was already drilled for the chevy frame mounts, yours almost certainly is too. Just buy 72 Chevelle.
See post 172 here for the Chevelle mounts.
https://classicoldsmobile.com/forums...ii-swap-5.html
garys 68&72 is offline
joe_padavano
Tech Editor's Desk
109
March 27th, 2022 06:28 AM
Jolly Green
August 3rd, 2015 07:30 AM
Se7enty5
May 12th, 2015 08:48 AM
Dissector
September 22nd, 2013 09:35 AM
80_cutlass
December 29th, 2010 09:38 AM
Quick Reply: dropping a 468 in my cutlass
