Rear axle and differential
Old May 17th, 2018, 04:38 PM
bluecutlassconvertable's Avatar
Are the rear differentials the same for 1968 and 1968 cutlass? Type O
I have a 1969 open with 2:56 gears and may have access to a 1968 with 2:73 gears. Is it worth it or is this to small a difference?
bluecutlassconvertable is offline
Old May 17th, 2018, 07:07 PM
Welcome to the site. You won't like those gears either.
oldcutlass is offline
Old May 17th, 2018, 08:01 PM
Randy C.
rcorrigan5's Avatar
The Type "O" differentials are the same for both years. You'll still get pretty good gas mileage with the 2.73 and it should be a little quicker (not much, but a little) than the 2.56.
Randy C.
rcorrigan5 is offline
Old May 19th, 2018, 05:05 AM
Out of Line, Everytime😉
olds 307 and 403's Avatar
Type O would be 2.78, you run a few hundred more on the highway, leave it alone. I have those gears and added a TH350C to have similar cruising RPM to the 2.56 gears.
olds 307 and 403 is offline
twilightblue28A
Drivetrain/Differentials
April 9th, 2016 07:13 AM
fv64olds98
May 10th, 2013 06:47 AM
cutlasssupreme71
February 22nd, 2011 11:40 AM
MY76GUTLASS
January 22nd, 2011 07:36 PM
Threejdsolds
March 31st, 2009 05:04 PM
Quick Reply: Rear axle and differential
