hood insulation
Old May 16th, 2018, 08:28 PM
Tiberian Fiend's Avatar
hood insulation
What does it do? Do I need it?
Tiberian Fiend is offline
Old May 16th, 2018, 08:43 PM
cjsdad's Avatar
Keeps engine heat from ruining the paint on the hood. Depends on how much under hood heat your engine generates and how attached you are to the money it costs to repaint your hood/car.
cjsdad is offline
Old May 17th, 2018, 06:54 AM
Actually, the insulation is more for sound deadening than it is for heat insulation. I've run many Oldsmobiles with the pad missing with no ill effects to the paint. The "reduced sound deadener" claim for the W-cars is simply the deleted hood insulation pad, since it couldn't be used with the O.A.I. hood anyway.
joe_padavano is offline
Old May 17th, 2018, 06:54 PM
Thanks, Joe. I had to stick a low-profile air cleaner on my car and it was being smothered by the insulation.
Old May 17th, 2018, 07:27 PM
I removed mine long ago and never replaced it. The Texas sun will probably kill my paint long before the engine heat does.
oldcutlass is offline
Old May 17th, 2018, 07:49 PM
Rocketbrian's Avatar
Definitely for sound and not heat, as F85s being the base model did not receive hood pads.
Rocketbrian is offline
flatfoot
August 24th, 2020 04:52 PM
costpenn
January 2nd, 2018 06:46 AM
d4rksabre
January 29th, 2014 10:30 AM
HouTXCutlass
January 10th, 2011 12:58 PM
richeyb
October 11th, 2010 06:44 PM
Quick Reply: hood insulation
