1970 intake gasket
1970 intake gasket
Anybody ever have trouble with the rubber front and rear rubber intake gaskets squirting out of place when alum. Intake is tightened down ??? Thanks. Greg
Your supposed to throw the rubber end seals away with an aluminum aftermarket intake. Use a bead of RTV in its place. Read installation procedure on page 2.
http://www.edelbrock.com/automotive/.../3000/3711.pdf
I agree that the rubber end seals are worthless, and I've found that Permatex Ultra Black is the best RTV for intake sealing (I really like the aerosol package). The fact that E-brock suggests using only their intake gaskets has more to do with profits than reality, however.
Our Ultimate Sealing Kit will seal your manifold correctly!
https://m.facebook.com/story.php?sto...08309059257851
Thank you in advance,
Bernard Mondello Racing Enterprises, Corona, California. 951-371-1432
Subscribing, I'll be swapping out a Performer for a W455 soon and have contiplated which direction to go on the end seals. I've also questioned to go metal or paper. I've done this both ways in the past, but would like to avoid problems and do the job once.
86GutlessCutlass
May 30th, 2016 08:58 AM
harry k
November 21st, 2012 08:54 AM
dallasite21
June 20th, 2010 05:37 AM
