divorced choke manifold, stove choke carburetor...what to do?
Old January 30th, 2018, 06:47 PM
rocketcouple's Avatar
So I have a 68 455 from a Toro and the intake manifold is setup for a divorced choke. The quadrajet carburetor that I have is setup for a hot air stove choke.
Does anyone know if I could still use the hot air choke on the carburetor and just run a line somewhere along the intake or exhaust since my manifold doesn't have a stove?
thanks!
edit: oh and I'd prefer to not switch to an electric choke if possible.
rocketcouple is offline
Old January 30th, 2018, 08:18 PM
cherokeepeople's Avatar
sure.well i don't know.years ago there was a kit made that had a 5 ft long or so piece of tube that would go to the carb then you just bent it to fit and run it along the ex manifold and clamp it to the manifold.but i haven't seen a kit like this in a looonnnggg time.but all you would need is say a piece of 5/16th brake line cut one of the flares off get a nut and make your own. the more length along the manifold the better.
cherokeepeople is offline
Old January 30th, 2018, 08:36 PM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
Lots of options here. Converting the carb to electric choke is likely your simplest least expensive.
Plenty of vendors offer this. Be sure to run the choke off a "keyed" 12vcd source.
droldsmorland is offline
Old January 31st, 2018, 07:50 AM
Agreed. This is what folks do when they install an aftermarket intake manifold that doesn't have a hot air choke provision.
Search the forums and you will find lots of info on wiring the electric choke.
Fun71 is offline
Old January 31st, 2018, 10:59 AM
allyolds68's Avatar
I asked a similar question a while ago but I was mostly looking for an electric choke alternative because the simple conversion kits used on the 70 and later carbs don't work on the 69 and prior:
https://classicoldsmobile.com/forums...-69-q-jet.html
allyolds68 is offline
nsnarsk65cutlass
February 4th, 2014 07:01 PM
yeahbuddy
April 21st, 2011 11:20 AM
oldsman7
March 25th, 2011 10:08 AM
remigus
August 23rd, 2008 09:48 PM
mitsudave
February 26th, 2007 12:30 AM
Quick Reply: divorced choke manifold, stove choke carburetor...what to do?
