Please help me!!!!!!!!
Old December 29th, 2017, 06:49 PM
  #41
steverw's Avatar
Picture #34, that would be the second to last picture, I see a wire coming from the distributor to the negative post on the coil. That wire is correct, the other taped wire, the one with multiple wires needs to go to the positive side of the coil. Again leave the single black wire on the coil and the multiple taped wire on + positive.
See if that works
steverw is offline
Old December 29th, 2017, 06:58 PM
  #42
tim30's Avatar
I just pulled a plug cut off all lights and had the wife to bump the starter and it's blacked out with no spark
tim30 is offline
Old December 29th, 2017, 06:59 PM
  #43
tim30's Avatar
I still have a bumper wire connected straight to the coil positive
tim30 is offline
Old December 29th, 2017, 07:16 PM
  #44
tim30's Avatar
See if that works
Did what you said just now with new battery since the trying killed the other one... still nothing
tim30 is offline
Old December 29th, 2017, 07:29 PM
  #45
steverw's Avatar
If that single black wire I see on the positive side of the coil is from that small body on the coil bracket, take it off. Only the double wire goes to the positive, and only the single wire from under the distributor goes to negative for now.
steverw is offline
Old December 29th, 2017, 07:32 PM
  #46
tim30's Avatar
Ok Done. Still didn't start only turning over
tim30 is offline
Old December 29th, 2017, 07:37 PM
  #47
cherokeepeople's Avatar
you said you took the distributor off?correct.if so did you get it back in correctly.pull number 1 plug and turn engine and feel for compression,then check the timing pointer and line up the marks then see where the rotor is pointing,then check with cap to see if it's anywhere near the number 1 terminal.
cherokeepeople is offline
Old December 29th, 2017, 07:40 PM
  #48
tim30's Avatar
Yes I took it off which now I wish I never have. I'm about to do as you said now
tim30 is offline
Old December 29th, 2017, 07:46 PM
  #49
tim30's Avatar
This is the timing pointer correct? The little notch? Also where should it be pointing
tim30 is offline
Old December 29th, 2017, 07:47 PM
  #50
tim30's Avatar
Once I feel the compression on spark plug whole what do I do
tim30 is offline
Old December 29th, 2017, 07:51 PM
  #51
tim30's Avatar
[I]This is where it stopped at for spark plug hole one compression. The pointer is pointing towards the passenger side and the number one plus is on the driver side
tim30 is offline
Old December 29th, 2017, 08:00 PM
  #52
turn the crank till that line on the balancer lines up with the 0 or usually deepest valley on that pointer tang.then pull cap and see if rotor pin lines up with the no.1 terminal of the cap
  #53
csouth's Avatar
Have you verified that the coil is actually providing spark? Have you disconnected the coil wire at the distributor and spun the motor to see if you're getting spark?
csouth is offline
Old December 29th, 2017, 08:10 PM
  #54
if you can't make out the 0 on the pointer just line up line on balancer with middle of the tang.
Old December 29th, 2017, 08:12 PM
  #55
tim30's Avatar
Yes I tried this and I'm not getting any
tim30 is offline
Old December 29th, 2017, 08:15 PM
  #56
just to clarify,the timing marks are on that little tang above the balancer with the saw teeth on it,it's on the drivers side of the engine behind the power sterring pump sometimes its hard to see down there..clean off the top of it and you will see lines and numbers.0 is top dead center.
Old December 29th, 2017, 08:37 PM
  #57
tim30's Avatar
Thanks for the Clarification I was surely about to ask but i will do that
tim30 is offline
Old December 29th, 2017, 08:58 PM
  #58
usually the no.1 terminal on the cap will point towards the number 1 plug.don't know if they planned it this way!!
Old December 29th, 2017, 09:41 PM
  #59
Proud Viet Nam Veteran
redoldsman's Avatar
Sounds like it may be time to call in the Calvary on this one.
redoldsman is offline
Old December 29th, 2017, 09:47 PM
  #60
tim30's Avatar
I know. And I would hate to get it towed to some shop Im not familiar with. Im military and just got station here two months ago and dont want my baby in just anybody hands you know
tim30 is offline
Old December 29th, 2017, 09:59 PM
  #61
redoldsman's Avatar
Thank you for your service and I hope you get your car going soon. It shouldn't take a good experienced mechanic more that an hour to get your car going.
Old December 29th, 2017, 10:04 PM
  #62
tim30's Avatar
tim30 is offline
Old December 30th, 2017, 02:14 AM
  #63
Verify that you have the rotor pointing to the #1 spark plug with the timing mark on the balancer pointing to 0 on the tab. Make sure the points are gapped to .016 and are in good condition. Make sure your firing order is correct for the spark plugs.
Pull the heavy coil wire in the center of the coil. Have a helper turn the key on and check that you have voltage at the coil+ terminal with the ign key in both the run and start position.
Put your test light on the coil- side, crank the engine with the key. The test light should flash. Reinstall the heavy coil wire and see if the engine will start. If it will not start, pull a spark plug wire and insert a screwdriver in the end and hold the metal shank near the block and see if there is spark.
If you have spark verify you have fuel by operating the throttle linkage while looking down into the carb, verify 2 solid streams spraying.
If you have all this you may need to rotate the distributor cw or ccw a bit while cranking. Keep body parts away from the top of the carb while cranking.
This is a good read:
https://classicoldsmobile.com/forums...-ignition.html
oldcutlass is offline
Old December 30th, 2017, 07:41 AM
  #64
zeeke's Avatar
Joe mentioned before, check the wire from the negative side of the coil to the points on the distributor. This can be done 2 ways, the first is take the "-" wire off the coil and with a continuity tester go from the open side of the wire to the points terminal. No continuity the wire is bad. If you do not have a continuity tester then leave the wire on, turn the ignition on and put your test light leads from the terminal on the points to a good source of ground. If you are not showing power then you need to start tracing your wires. If you are then follow the steps Eric mentioned in the post above this one.
Above all slow down and take a deep breath. If you need to walk away for a while then do so. Moving wires all over to see what works is never a good way to solve the problem. These systems are very simple if you take a few minutes to learn them there is light at the end of the tunnel.
Thank you for your service.
zeeke is offline
Old December 30th, 2017, 10:02 AM
  #65
tim30's Avatar
I verified and set timing just now to all specs
This is the firing order I have used
tim30 is offline
Old December 30th, 2017, 10:03 AM
  #66
tim30's Avatar
The distributor pointer is now sitting on the number one spark plug. When I checked it before changing it just not it was on the number 4
tim30 is offline
Old December 30th, 2017, 10:07 AM
  #67
tim30's Avatar
Im getting gas to the carb jets and I don't have a tester for the coil is there another way?
tim30 is offline
Old December 30th, 2017, 10:51 AM
  #68
redoldsman's Avatar
Was the car running before you pulled it apart? If you are getting power to the distributor it should be at least sputtering or backfiring out the carb.
Old December 30th, 2017, 11:10 AM
  #69
tim30's Avatar
Yes it was running beautifully. This is what I did. Changed All plugs and plug wires took distributor off to remove Manifold and changed manifold gasket. Removed Valve Covers and changed its gaskets. Everthing on the car was from factory so it was in dire need of changing since they never was changed before. I was getting oil leaks from both valve covers and from behind the manifold (close to the firewall leaking on top of tranny). I kinda wish I wouldn't have touched it because it ran like new but the leaks was annoying The valve cover gaskets was so old the cork gaskets was cement hard to scrape off
tim30 is offline
Old December 30th, 2017, 11:54 AM
  #70
redoldsman's Avatar
This may sound a little like a smartazz but it is not intended to. You did remember to put the rotor back in and make sure it seated properly on the distributor. I am sure you did since you indicated where it was pointing.
Old December 30th, 2017, 12:20 PM
  #71
tim30's Avatar
Yes I did and also got the two strews turned into the casing to make sure it's down all the way
tim30 is offline
Old December 30th, 2017, 12:27 PM
  #72
tim30's Avatar
I just went and got a new coil and it's still doing nothing
tim30 is offline
Old December 30th, 2017, 12:44 PM
  #73
So your still not getting spark at the plugs?
Old December 30th, 2017, 01:00 PM
  #74
tim30's Avatar
No
tim30 is offline
Old December 30th, 2017, 01:01 PM
  #75
tim30's Avatar
I took everything off the coil. Put a jumper wire to the (+) and the (-) wire to the distributor and I still have nothing
tim30 is offline
Old December 30th, 2017, 01:08 PM
  #76
redoldsman's Avatar
Take the car off and have somebody crank it over and see if the points are opening and closing.
Old December 30th, 2017, 01:15 PM
  #77
Do not jumper things for ***** and giggles because you will cause damage.
Again, you are sure that the rotor is pointing to the #1 spark plug terminal in the cap with engine at TDC?
Did you make sure the point gap is set to .016?
Remove the wires off the coil+ terminal and tape the ends for now. With an ohmmeter, check continuity of the wire between the coil- terminal and the points terminal inside the distributor. Also check continuity between the plate that the points mount to and the engine block.
Remove the coil wire at the center of the cap, stick a long screw driver inside the wire boot and hold the shank near some metal. Run a temporary 14 or 12ga wire direct from the battery positive cable to the coil+ terminal. Have someone crank the engine and see if there is spark at the screwdriver jumping to ground.
If still no spark remove the jumper wire and replace the uniset points, the condensor is probably bad. Redo the test.
Old December 30th, 2017, 01:35 PM
  #78
tim30's Avatar
I'm very sure it was set at top dead center
tim30 is offline
Old December 30th, 2017, 01:41 PM
  #79
Perform the other tests and report the findings.
Old December 30th, 2017, 02:45 PM
  #80
zeeke's Avatar
You went through the trouble of going out for another coil you should have picked up a test light. You still have not established if the wire from the negative terminal on the coil to the points contact is broken or not. You will most likely not see that break it has to be done with a tester. If that wire is broken you will never get power across the points. I had 3,500 miles on a brand new AC Delco distributor over the summer and that wire went bad. It's 46 years old and yes moving it around could cause it to be damaged. Changing parts to get results can get costly, so the best method is to troubleshoot and eliminate what's not broken. I doubt your coil is bad since you've installed a new one and still have the same issues.
zeeke is offline
Quick Reply: Please help me!!!!!!!!
