th400 duel gate shifter holder
70 th 400 have a hurst duel gate.
The shifter will not go into 1st
the bracket on the transmission seems to be too short for the correct shiftier/ cable.
Does the auto / duel gate have a different bracket that mounts on the transmission?
Did you use an aftermarket shift lever on the gear selector shaft?
I did with my DUAL gate and the slot is too short to allow proper adjustment of the cable to get it into low or 1st gear. I took a Dremel to it and lengthened the slot about 3/8 inch
the new cable from the parts place is 18 inches , same 30inch total length.
I'm thinking my trans was swaped/ meeting the bracket to hold this cable is too long by 1.5 to 2 inches.
kinda like I have the wrong bracket at transmission.
Dale Von Krosigk
October 1st, 2013 01:54 PM
ah64pilot
May 29th, 2012 03:04 AM
