.040 over 10.50:1 forged flat tops for W31
So, anyone have these in this bore? (4.097). I looked quite awhile back, and none existed, talked to Arias at the time, and he wanted $1200.00 to make a set with rings and wrist pins. Curious as to whether or not any manufacturer has introduced them.
Have a look at this post for a new piston choice.
https://classicoldsmobile.com/forums...5-pistons.html
I read that when it was posted, the compression is lower that what I want. I am skeptical of the 10-12 hp gain claimed. I do like that 4.100 is right about where I want to be for the bore, as I don't want to go to .060 over if I don't have to. The lightweight is also a plus.
https://www.summitracing.com/parts/dms-6020x-4100
These will be closer to what you want with a better than stock ring pack.
Thanks for the replies, I'll take a closer look into these, and the silicone info. Best friend is a senior applications eng. for Mahle, knows a few things about pistons and rings.
I was being sarcastic about their "silicone" statement.
Silicone is a rubber like polymer and silicon is a hard, brittle crystalline element. Totally different things and you don't want to use the wrong one in either breast implants or pistons.
DSS Racing Pistons
https://dssracing.cld.bz/DSS-RACING171/36-37#zoom=z
here's a 350 Olds piston for you in a 4.100" (0.043" overbore).
I have no personal experience with this piston but they were discussed on Facebook a few months ago with positive comments.
Dave
I was being sarcastic about their "silicone" statement. Silicone is a rubber like polymer.
DSS Racing Pistons
Contact information for D.S.S. is at the bottom of the page in the link. They are an IL USA based company. The pistons are made in USA.
http://dssracing.com/ is their home page
I believe the bores which are similar to the Mahl pistons Mark help bring to market is for common ring packs size. The KB 403 pistons used goofy oversizes to work with Ford 460 rings. In this case it may be LS bore sizes since the world revolves around it.
joesw31
January 23rd, 2016 09:07 PM
oldspackrat
October 2nd, 2013 03:50 PM
