Best tool for "jacking up" a gas tank
Old November 6th, 2017, 03:10 AM
king_doodle's Avatar
My son (16 yo) and I are working on his 1970 Impala. We just replaced the fueling sending unit and we're having trouble getting the gas tank back into position so I can bolt the straps down. Does anybody have some advice on a tall jack or other tool that could be used to hold the tank against the bottom of the car?
king_doodle is offline
Old November 6th, 2017, 05:03 AM
WannaBa442's Avatar
I've used an ATV jack to lift things like that, even used it to R & R the powerpack on my '66 Corvair.
Usually they'll lift up to 30".
WannaBa442 is offline
Old November 6th, 2017, 05:25 AM
I just use a hydraulic floor jack. Put a piece of wood between the tank and the floor jack so you don't dent or scratch the tank.
Olds64 is online now
Old November 6th, 2017, 05:58 AM
WannaBa442 and Olds64: Great advice. Thanks for your guidance. --Craig
Old November 6th, 2017, 06:37 AM
Tedd Thompson's Avatar
X2, never been that much of a problem so far ... Tedd
Tedd Thompson is online now
Old November 6th, 2017, 06:55 AM
jaunty75's Avatar
This is just what I did when I replaced the tank on my '78 Toronado. I used a 2 by 4 about the width of the tank between the floor jack and the tank to spread the load out.
jaunty75 is offline
Old November 6th, 2017, 06:56 AM
X3 on the floor jack and some plywood.
oldcutlass is online now
Old November 6th, 2017, 07:19 AM
I've found a trans jack to be the best. In addition to the long travel, the trans jack has tilt ability at the head, which can help with alignment.
joe_padavano is offline
Old November 6th, 2017, 07:25 AM
Local Hero's Avatar
I usually just lay it across my chest and roll under the car and bench press the tank back up into place and while laying on my back, hold it with my knees while I get the straps started. No joke.
That works best if the tank is near empty.
If it's not, then I use the block of wood on the floor jack technique.
Local Hero is offline
Old November 6th, 2017, 07:33 AM
jaunty75's Avatar
Yes, but how many of us have on hand a transmission jack versus how many of us have on hand a regular floor jack?
Of course there's always a perfect tool for a particular job, but sometimes we have to work with what's on hand. I don't like to buy a tool, especially an expensive one, that I'm going to use only once unless I have no other choice. I don't change out the transmission on a routine basis, but I'm always jacking up the car itself to work on something. If I can make something I already have work, I'll do that.
jaunty75 is offline
Old November 6th, 2017, 07:48 AM
71 cutlass convertible
lshlsh2's Avatar
Used a floor jack with a chunk of 4x4 this weekend to drop mine. Will use it to put it back.
lshlsh2 is offline
Old November 6th, 2017, 09:05 AM
x2...
Um, never mind. I like buying tools no matter what. If I can use them more than once then that's even better.
Old November 6th, 2017, 11:31 AM
m371961's Avatar
But he did ask for the best tool.
m371961 is offline
Old November 6th, 2017, 12:08 PM
RROLDSX's Avatar
I have a motorcycle jack that seems to be ideal for not only jacking my Harley but transmissions, rearends, gas tanks. I’ve also used it to help angle my motor/transmission combo installs in easier. Works great. Mine is a cheap HF part that I’ve used frequently since 2002.
https://shop.harborfreight.com/media...mage_24958.jpg
RROLDSX is offline
Old November 6th, 2017, 03:14 PM
Olds Fever
CRUZN 66's Avatar
I use a trans jack... One of my trans jacks is designed so that it can be used with a lift or jack stands...
CRUZN 66 is offline
Old November 7th, 2017, 03:02 AM
bccan's Avatar
I have been using threaded rod/nut combo. 2 pieces of threaded rod appx 16" to 18" long, ran a die over so integral washer nuts spin easily, pull one tank bolt & replace w/ rod, same for the other. Hold the tank up a little, spin nuts by hand & walk tank down. Walk it up for install, works great.
bccan is offline
Old November 7th, 2017, 08:12 AM
Thanks a million
A huge thanks to bccan, CRUZN 66, RROLDSX, m371961, Olds64, lshlsh2, jaunty75, Local Hero, joe_padavano, oldcutlass, Tedd Thompson, and WannaBa442. These are all excellent ideas. I really appreciate everybody’s assistance.
Old November 7th, 2017, 12:27 PM
72 Olds CS
RetroRanger's Avatar
prolly not the way you want to go but i jacked up my gas tank real good when i broke the driveshaft on my truck and put the stub end thru the side of the tank !!!!
RetroRanger is offline
Old November 7th, 2017, 12:31 PM
Yikes! Yes, that's a special kind of 'jacked up,' RetroRanger. It sounds like one of my smooth maneuvers.
junior supercar
June 26th, 2020 04:37 PM
70-442-W30
May 18th, 2016 02:09 PM
mefirst72
October 21st, 2012 09:14 AM
sx455raidercelticfan
January 12th, 2011 07:53 PM
Jamesbo
July 8th, 2009 01:34 PM
Quick Reply: Best tool for "jacking up" a gas tank
