Plastic Polish?
Old April 5th, 2009, 01:54 PM
Cameo White's Avatar
Smile Plastic Polish?
Hi guys,
I want to polish the surface scratches out of a couple sets of clear lenses (front turn signals and back up lamps) for my 69. Anyone got any helpful hints or know of any useful products?
Thanks.
Cameo White is offline
Old April 5th, 2009, 02:02 PM
Shoveling Snow
Hairy Olds's Avatar
Simichrome polish works the best for fine scratches.
Hairy Olds is offline
Old April 5th, 2009, 02:14 PM
Registered
Bluevista's Avatar
x2
Simichrome works great on plastic.
The tubes are too expensive for what you get.
Buy the small tub and it will last you about 50 years.
Bluevista is offline
Old April 5th, 2009, 07:11 PM
csstrux's Avatar
Ive always used 1200/1400 grit sand paper and/or rubbing compound
csstrux is offline
Old April 5th, 2009, 07:16 PM
Chumley's Avatar
I bought the plastic polish kit that Eastwood sells a couple of years ago, and it works fairly well on tail light lenses, which I have done several sets of. I still have a lot left of the 3 bottles you get. Chumley
Chumley is offline
Old April 10th, 2009, 05:31 PM
Coltonis's Avatar
Since no one else has mentioned them:
I personally have used Meguirs PLASTX on a couple of tail Light lenses. Got it at walmart. It does do a good job of cleaning grit and grime off (in my case there was greasy dirt and some rattle-can overspray mist that was on the lense). There was a slight bit of fogging that it also took care of and left a nice smooth shiny surface. That size bottle will last a while if you are doing it by hand too. Forget it if there is anything more than light hairline surface scratches though.
I had found a thread at one point, where somebody was asking about some craigslist guys that were promising to remove the frosted yellow tinge of your headlights. The OP was asking what products they most likely used, since they're pictures were quite compelling. I believe the final consensus was that they were using this stuff:
#17 MIRROR GLAZEŽ CLEAR PLASTIC CLEANER
#10 MIRROR GLAZEŽ CLEAR PLASTIC POLISH
Here's a link
Never used it myself but the pictures were awesome and the reports in the thread made it sound pretty "industrial grade".
Deep scratches may be a whole other story. If you've got lots of time - I too have used wet/dry sand paper method to polish copper blocks before and the results are literally a mirror finish. Start with 800 grit then 1200 grit with water, and then finish with 1400-1600 wet (such high grit is sometimes hard to find in stores though)
Coltonis is offline
Dan Wirth
Care and Appearance
February 7th, 2017 04:21 PM
hinz57
February 5th, 2012 01:16 PM
Railguy
November 2nd, 2010 09:06 AM
oldsmansugar
Care and Appearance
March 13th, 2010 02:38 AM
dman0712
December 6th, 2009 08:02 PM
Quick Reply: Plastic Polish?
