Bendix treacle vac
Old June 2nd, 2017, 10:24 PM
griffey57's Avatar
Bendix treacle vac
My power brake unit is failing on my 57 olds. I just had it rebuilt 4 years ago, it cost me $500 dollars. I am debating whether to rebuild it or replace it with a conversion
griffey57 is offline
Old June 2nd, 2017, 11:27 PM
59-59-59's Avatar
$500 4 years ago? You got ripped off. If the unit is actually bad, send it to Ed Strain in Florida to be rebuilt. He is listed in Hemings, along with other publications
59-59-59 is offline
Old June 2nd, 2017, 11:28 PM
griffey57's Avatar
Thanks for the info
Old June 3rd, 2017, 06:37 AM
"Treacle vac"?
You mean one of these?
MDchanic is offline
Old June 3rd, 2017, 07:05 AM
Proud Viet Nam Veteran
redoldsman's Avatar
I had the one on my 54 rebuilt by Karps in Upland, CA. I have been very satisfied. It was about $500-$550. Jeff is a good guy and has been in the business a long time. Here is the link.
http://karpspb.com/
redoldsman is offline
Old June 3rd, 2017, 09:07 PM
griffey57's Avatar
thank you
Old June 4th, 2017, 03:24 AM
flatoz's Avatar
I got rid of mine even after having it rebuilt and not being happy with the brakes. Plus I like the belts and braces idea of a dual master cylinder. Of course if you're going full points resto that won't work. But I also know I drive my car everyday, so my near misses are multiplied beyond just a Sunday cruise.
G body assemblies will work, again , not stock but guess it depends on how well you want to stop.
flatoz is offline
Old June 4th, 2017, 04:21 AM
tommieb's Avatar
Oh no
Drop that unit go with Power disc brakes. Don't ask me why?????????
tommieb is offline
Old June 4th, 2017, 06:16 AM
Tedd Thompson's Avatar
I drive mine all over the Western US and Canada with no issues that would make me change to disks. No doubt disks are a better system or the auto industries wouldn't have changed to it but mine are set up to slide the wheels if I have to in a panic stop. That's good enough for me, it's a classic not a Honda cevic.... Tedd
Tedd Thompson is offline
Old June 4th, 2017, 07:19 AM
griffey57's Avatar
Thanks, no full points resto, I drive her once a week and enjoy it. They are made to be driven
Old June 26th, 2017, 10:57 AM
supmarjo's Avatar
hi i just went thu this this last year. Had a guy up in Sacramento area rebuilt it.. did not hold up ,was leaking so i took it apart, and found it was a Bad rebuilt.
ended up installing a under floor master n booster,w remote res.
got the idea here..Olds Dad under floor power brakes 1955..
w disk brakes kit from Scarbird
system works very good
supmarjo is offline
Old June 26th, 2017, 11:25 AM
griffey57's Avatar
Thanks, I am going to switch over as well.
Old June 27th, 2017, 12:35 AM
flatoz's Avatar
check out the conversion I did, just search my name for posts ( not that many ) on the engine swap I did, I showed what I did there. I've seen underfloor units, but the idea of bleeding them etc I didn't like ( each to their own) My car as I said previously is a daily driver so I can say the swap works well.
I actually have drum brakes soon, I've just had a scarebird disc setup finally sorted out as it didn't fit like it should, so in the next month or two I will put that on too. Given the nuts traffic I encountered when in CA last year I can understand wanting better brakes.
flatoz is offline
Rocketowner
November 11th, 2014 12:54 PM
1970VistaCruiser
January 15th, 2013 06:16 PM
1970VistaCruiser
November 22nd, 2012 04:55 PM
PushRod
Brakes/Hydraulic Systems
March 30th, 2010 01:53 PM
lowdynamo
December 8th, 2008 04:48 PM
Quick Reply: Bendix treacle vac
