M22FHV Clarification Between Shimming & Spring Replacement
Old May 17th, 2017, 10:17 AM
gbledsoe3's Avatar
High Volume Oil Pump (M22FHV) Clarification Between Shimming & Spring Replacement
Re: High Volume Oil Pump
Trying to discern the difference between the two. After reading around various places, I understand that shimming is adding shim to the existing spring. Like this found DMR site.
OR
One could replace the existing spring with the 'purple' spring to get the same result.
Please advise if I have that right or please correct me.
gbledsoe3 is offline
Old May 17th, 2017, 05:02 PM
cjsdad's Avatar
It might help get more answers if you explain that M22FHV is an oil pump (I googled it). It also might help if you explain why you want to shim or install a different spring. You are right that adding a shim will increase the spring tension a small amount but only as long as the spring still has enough room to compress. Personally I have no idea which would be better for an oil pump. Someone else might have more info for you.
cjsdad is offline
jmos4
June 19th, 2016 08:15 PM
cdrod
December 14th, 2015 01:10 PM
Arrowstorm
January 27th, 2015 03:38 PM
chasman414
February 11th, 2013 10:43 PM
Gary Lagacy
September 20th, 2008 01:35 AM
Quick Reply: M22FHV Clarification Between Shimming & Spring Replacement
