1972 cutlass supreme
Hello folks,
I need to replace the chrome plastic front armrest backing plates. Unfortunately the diagram is not in my factory assembly manual. Could someone post a pic of the armrest assembly diagram so I know what to do please?
Remove the arm rest from the door panel. You will then need to remove the panel from the door. **NOTE** This is a good chance to grab a magic eraser or something else to clean the door panel. The backing plate is held on with clips from the back. If you go to the Fusick website, you can find replacements there.
I just finished doing this and it is no problem at all.
1k442
Cars Wanted
November 10th, 2017 01:35 PM
olds70supreme
August 1st, 2011 05:22 PM
