Odd control arm
Odd control arm
Going through my control arms and found this pair with bolts instead of nuts. Anyone no why these are different? I only part 68-72 so it has to be one of those. Thanks Brandon
I think that's the Chevy (& maybe B or P? ) setup with the bolts. I have a bagged set of the bolts & big washers that I acquired somehow that says "68-72 Control Arm". If those came off an Olds, maybe someone replaced the shaft & nuts with the C style parts ??
Factory setup for 66... My 442 has that style shaft setup and I believe my 67 does as well... I also have a spare set of control arms like that and I never parted out any 68-72 front suspensions (only 66 & 67)...
68-72 cutlass/442 used the nut style. This style(Bolt) was used on Chevelle's for sure, Chevelle never used the nut style in these years. I don't know about Pontiac/Buick.
Either style will fit the same arms. so if they were replaced some one could use Either style
I bought a front end rebuild kit from PST suspensions last year for my 70 442. The cross shafts with the bolts in the picture are exactly what I got. I knew they were wrong and didn't use them. Too late now to send them back. At least now I know they are for Chevelle. Buyer beware on these at PST..
Early 68 442 Cutlass have the nut as well. Those are Chevelle upper shafts. The A arm stamping is generic but no idea why Chevy uses a different set up?
Someone likely installed them on one of the Olds you parted. They will fit and function the same.
http://www.ss396.com/chevelle/BPX-8542.html
oldzy
December 19th, 2011 06:43 AM
MeanGrnGt
Brakes/Hydraulic Systems
July 20th, 2008 05:34 PM
