Jetfire vs Cutlass Air Cleaner Pie Pan
I have a 67 Cutlass Supreme Convertible. I believe the engine is the High Compression 330. Im assuming the High compression part due to its dislike for anything less than Sunoco ultra, the Quadrajet, red air cleaner housing(obviously could have been easily changed, but i doubt it) and general feeling of power. The question i have is what pie pan should it have assuming it is the HC engine? The pie pan was missing when I bought it. Its obviously of the the 10" diameter as opposed to the 2 bbl 7". Is it the "Jetfire Ultra High Compression" one or the "Cutlass" one? My thought is that it should be the "Jetfire Ultra High Compression" one. Either way that one looks cooler and is probably what I'd get anyway, just curious on which one is correct. Thanks
Mike
Mike
