4 door interchange 2door
Old March 12th, 2017, 10:22 AM
oldsmobilejuggernaut's Avatar
70 Cutlass floor
If a removed a floor from A 71 4 door cutlass will it work for a 72 cutlass convertible floor ? I looked at the two and seems very close
oldsmobilejuggernaut is offline
Old March 12th, 2017, 02:32 PM
I have 71 4door with pristine floor and trunk, would Ithe floor pans be interchangeable with a 70 conxertible?
Old March 12th, 2017, 02:57 PM
Nope. The 68-72 A-body 2dr cars used a 112" wheelbase. The 4dr cars used a 116" wheelbase. Floor pans are different as a result. You MIGHT be able to cut patches for the front seat footwell area, but that's about it. The trunk floor can be used.
I merged your two identical threads. It is not necessary nor in your best interest to ask the same question multiple times. You'll get a better answer more quickly when all responses are kept in one thread.
joe_padavano is offline
Old March 12th, 2017, 04:28 PM
Carshinebob's Avatar
Joe is right. they're different, however you can use the floor from about the back of the front seat forward and the trunk floor is the same on two or four doors. there are small differences between 70 and 71, but nothing that would stop you from using it. ~BOB
Carshinebob is offline
Old March 24th, 2017, 09:07 AM
outlawspeeder's Avatar
From what I have seen, the floor pan, front half, will replace a two door. The back half I plan on using for my two door 70 but will modify the panel as as need.
outlawspeeder is offline
Fathers_Olds
June 28th, 2016 11:04 AM
Fathers_Olds
June 27th, 2016 06:55 PM
getnolds
June 28th, 2011 05:57 PM
64rocketman
July 15th, 2009 08:43 AM
aussieolds
Cars Wanted
March 31st, 2008 06:35 PM
Quick Reply: 4 door interchange 2door
