72 Cutless Supreme Instrument Cluster
I'm trying to help someone order an oil pressure/ water temp guage to put in place of the clock position that has a blank on it. We want one dual or one quad guage in that hole. What size hole is that? The car is not in town right now. It's being shipped. Who should I order the guage from. any help would be nice. Car is 72 Cutless Supreme.
Speedhut has a large variety of gauges in a number of sizes. As for size...get a car/dash, remove the bezel...take accurate measurements. Another option is the rally pack.......repops available from most of the parts houses (fuel/temp/pressure) made to fit(left of speedo)....will look like the speedo......a tach would fit in the clock opening....could get a (tic-toc-tach)
Any common 3 3/8" gauge can be mounted to the gauge panel. It will be in FRONT of the panel, while the other gauges are BEHIND the panel. Doesn't look fantastic, but quick, cheap, easy.
With time and creativity you can fabricate a mounting ring that mounts in the stock place and holds an aftermarket gauge. Clearance with the gauge panel will be a challenge, but the gauge certainly can fit in there.
Rally pac is swanky, but there are wiring mods and $$$ that go along with that.
