Grease for ball joint and tie rod
Old September 26th, 2016, 07:11 AM
ilanzo's Avatar
Hi. Got red grease for wheel bearing, and grafit grease for cv joints. Which one is better for ball joints and tie rods?
ilanzo is offline
Old September 26th, 2016, 07:34 AM
4 Barrels of Laughs
quaddriver's Avatar
Location: I moved to pittsburgh so I can be near Primantis
any high pressure grease you can pump in there. I typically use just wolfs head red and I use a hi temp 'tan' color for wheel bearings and of course lithium added 'green/blue for the boat trailer stuff
quaddriver is offline
Old September 26th, 2016, 11:24 AM
Any standard rated grease is fine for front end parts.
oldcutlass is online now
Old September 26th, 2016, 02:11 PM
Tastefully Hooped
L77F85's Avatar
i would stay away from the synthetic lubricants for the stock front ends of our cars. from my experience it tends to get "liquidy" & runny over time. i rebuilt the front suspension on 2 of my previous vehicles & used hi-temp synthetic grease for my bearings & synthetic grease for ball joints & steering components. after about 6 months to a year time frame i noticed that i had a wet, greasy film on the back of both front wheels. i noticed small droplets of the reddish grease dripping out from some of the zirk fittings as well. i also had a greasy runny film all around the lca ball joint & lca. i use standard bearing grease (for bearings) & good old black chassis grease for bj's & steering components now. haven't had a single issue since
L77F85 is offline
rothlane'68
November 29th, 2015 06:54 PM
defiant1
March 16th, 2015 09:44 AM
kstern58
December 28th, 2014 10:57 AM
Creativeindy
Suspension & Handling
26
September 11th, 2012 04:25 PM
yankees
December 1st, 2011 02:10 PM
Quick Reply: Grease for ball joint and tie rod
