The new FiTech injection works great!
Old May 23rd, 2017, 06:40 AM
  #41
Gary M's Avatar
Fitech distributor answer
This is the response I got to my question about what dist to use and if a pertronixs 3 would work. I asked if they had any recommendations as far as distributor.
"Hi Gary, in order to use the timing control the distributor must be a 2 wire
magnetic pick up type. We have had good luck with MSD distributors."
Mario De Leon
Technical Manager
FiTech Fuel Injection
Gary M is offline
Old May 23rd, 2017, 07:02 AM
  #42
Interestingly, the only distributor Summit lists which is computer control compatible is the FAST 305018.
https://www.summitracing.com/search/...0%2B4294930064
The MSD distributors have one with vacuum advance and an additional one with mechanical advance only:
https://www.summitracing.com/search/...44559%2B400122
It was my understanding that in order to use a distributor with the EFI system the advance had to be locked out completely...
I would contact FiTech before purchasing a system. I would definitely want a definitive answer on what distributor provides timing control.
Olds64 is offline
Old May 23rd, 2017, 07:15 AM
  #43
Gary M's Avatar
My original question to Fitech
"I have a 1972 cutlass with a 455 motor. Mild cam and auto transmission
presently ( to be changed to manual transmission later).
I understand you have a unit that controls the distributor. My question is
will your unit control a billet distributor with a pertronixs lll unit in
it? Do you have a suggestion as far as what distributor to use?"
I looked at multiple vendors also trying to find a distributor that can be computer controlled and finally asked Fitech.
You may need to ask Fitech for specific distributor brand and part number to get the right one.
Gary M is offline
Old May 23rd, 2017, 07:33 AM
  #44
Apparently, FiTech also mentions that the distributor must be phased:
https://www.summitracing.com/parts/msd-84211
Olds64 is offline
Old May 23rd, 2017, 09:24 AM
  #45
Gary M's Avatar
Side note
One more thing, I read somewhere a thin metal plate may be needed between the "stock" intake and Fitech carb. To prevent vacuum leaks. Looking for that source again to post here. BRB
Gary M is offline
Old May 23rd, 2017, 09:28 AM
  #46
Gary M's Avatar
Quote from Fitech question and answer website
"You need a 2 wire distributor ‘locked out’ ( this is easily done on MSD or equal distributors) like Summit or Jegs brands."
Gary M is offline
Old May 23rd, 2017, 09:29 AM
  #47
ph_ckstick1
midnightleadfoot's Avatar
Originally Posted by ART T
I bolted a 600 hp unit onto my stock 64 manifold and I needed a 1/4" spacer so the carb linkage would clear the manifold.
So far I've seen all the 4 barrel tbi's working better with a spacer or the divider in the intake milled down.. have not seen dyno pulls with a factory q jet intake yet.. but the dual planes with solid divider have fueling issues.. And milling the divider some fixes the a/f issues to some cyl. and picks up some power to boot..
midnightleadfoot is offline
Old May 23rd, 2017, 09:36 AM
  #48
You mean milling this part of the intake?
It's interesting that a single plane manifold runs better than a dual plane manifold.
Anyone else hear about this?
Olds64 is offline
Old May 23rd, 2017, 09:50 AM
  #49
ph_ckstick1
Single planes ?? yes on multi port efi..
on the tbi you mill the divider a little,, not hog it out
Old May 23rd, 2017, 12:39 PM
  #50
Gary M's Avatar
Took me long enough to find it but here it is
a poster on the facts and answers at Fitech.com
"I have spread bore intakes {quadrajet style] will it bolt up or do I need an adapter"
Bryce - FiTech Tech Pro October 13, 2016 at 3:16 pmReply The FiTech throttle bodies will bolt to a spread bore intake. They might not seal properly so you may still need an adapter.
Gary M is offline
Old May 24th, 2017, 05:47 AM
  #51
JSPajak's Avatar
http://realoldspower.prophpbb.com/topic9853.html
19+ pages of experiences there.
JSPajak is offline
Old May 24th, 2017, 12:59 PM
  #52
Gary M's Avatar
EDIT: This adapter did not work due to butterfly interference with the FiTech.
Jegs<br/>Weiland adapterWeiand 9006
Carburetor Adapter Square Bore Carburetor to Spread Bore Manifold part # 925-9006
Going to try this one because its only 1/16 thick. DOES NOT WORK. BUTTERFLY INTERFERENCE.
Gary M is offline
Old June 20th, 2017, 04:09 PM
  #53
RetroResto's Avatar
I tried that adapter.. too thin. It didn't work for me on my 350.
RetroResto is offline
Old June 20th, 2017, 06:06 PM
  #54
Gary M's Avatar
Did it leak or was there another problem with it?
Gary M is offline
Old June 20th, 2017, 06:27 PM
  #55
RetroResto's Avatar
I had butterfly clearance issues with my fitech trying to use it with a spread bore manifold.
Had to go with a 7/8 adapter to make it work.
Unless I was missing something I can't see how it would work with factory intake?
Old June 20th, 2017, 06:37 PM
  #56
Gary M's Avatar
Interesting. It's listed as a spread bore/square bore adapter. Do you have the OAI hood? If so does the foam air cleaner fit right with the 7/8 adapter?
Gary M is offline
Old June 20th, 2017, 06:54 PM
  #57
RetroResto's Avatar
No my hood is just an S hood.
I used the spacer from speedway motors.
http://www.speedwaymotors.com/Univer...lQuery=1351932
If you have a square bore intake ( as in holley will bolt on) you are fine, and will not need any adapters.
I used a Tanks inc. Fuel tank with in tank pump.
I'm happy with the unit so far. I have only put on about 400 miles, and there a few fine tuning issues I need to make but otherwise its great.
Old July 13th, 2017, 06:50 AM
  #58
RetroResto's Avatar
I was curious if you ever put the fi tech on?
Old July 13th, 2017, 03:48 PM
  #59
Gary M's Avatar
I haven't
I've been working 80+ hours per week lately.
Gary M is offline
Old July 13th, 2017, 04:03 PM
  #60
RetroResto's Avatar
80 hours doesn't leave much time for fun.
sure does help in the Cash dept. though
Old July 14th, 2017, 02:12 AM
  #61
bw1339's Avatar
What improvements are you seeing?
bw1339 is offline
Old July 17th, 2017, 01:59 PM
  #62
RetroResto's Avatar
Possibly near the top of my list would be the warm starts! Bump the key..
But I would have to say all starts are improved.
Much stronger and responsive throttle response.
I'm sure these can all be achieved with a good carb too, but that's something I didn't have.
Old July 17th, 2017, 05:57 PM
  #63
Gary M's Avatar
That quick start makes a big difference. I hate the cranking the old cars need to start. Does it sound about the same or stronger? I can't wait to get one on my 455. Don't remember, can you now use regular unleaded instead of the premium gas?
Gary M is offline
Old July 17th, 2017, 07:06 PM
  #64
RetroResto's Avatar
I should mention the sound is heavy vacuum, if i am at 1500 rpm and kick it down on the road it's distinct sound I love it! And the response. It resembles a modern car.
I'll be honest I have run 91 octane all the way down to 87. I did NOT notice a bit of difference. I read on the Chevelle forum where a guy was running E85
richkidd24
June 3rd, 2016 02:53 PM
ohiocutlassparts
December 10th, 2013 02:54 PM
Oldssupreme
January 10th, 2013 07:35 PM
coppercutlass
December 31st, 2012 04:02 PM
BlueBlock350
April 9th, 2008 10:38 AM
Quick Reply: The new FiTech injection works great!
