70 TH350 Speedometer gear housing seals
Old June 5th, 2016, 03:03 PM
Del70's Avatar
I have the the typical leak at the speedometer cable. Need to replace the seal/s for the speedometer gear shaft and since I need to remove the gear housing, I will replace the housing O-ring. Has anyone replaced the seal/s in the housing? How do you remove the inner seal for the gear?. Best place to get them?
thanks.
Del70 is offline
Old June 5th, 2016, 03:34 PM
Pretty much anywhere. Type TH350 speedometer seals into Google.
Dozens of sources come up, including local auto parts stores. Going rate for the kit seems to be under $15.
joe_padavano is online now
Old June 6th, 2016, 03:24 AM
Del70's Avatar
Thanks – The image shown above appears to be the bullet type, not the gear housing type for 70 Olds TH350. Was able to find the large housing seal with the inner seal at $10-20, I think I will keep looking to get them local, no hurry so I will see what I can find…Also I have read the plastic gear can develop a groove, so it might make sense to buy the gear too or if it prices out, a new assembly which I found them to be in $45 rang. Will see how much the parts are, shipping etc. I still would like to understand how the inner seal is removed from the housing?
thanks
Del70 is offline
Ronaldwayne
September 28th, 2015 05:09 PM
ddd777
May 24th, 2015 12:52 PM
at3reg98
November 3rd, 2013 04:48 PM
jpc647
August 3rd, 2013 10:00 AM
jensenracing77
May 15th, 2011 05:04 AM
Quick Reply: 70 TH350 Speedometer gear housing seals
