does brand matter in power steering fluid?
Old March 11th, 2016, 09:28 AM
top down's Avatar
Just had my steering gear and pump rebuilt by Chip at Powersteering.com
Upgraded from 16:13:1 variable ratio to 12.7:1 constant ratio - can't wait to drive it!
Instructions say to refill the system with dexron 3 power steering fluid - does brand matter? Advanced Auto store brand, or should I shop around for better?
and...will 2 quarts be enough? (1970 cutlass supreme)
Thanks!
top down is offline
Old March 11th, 2016, 10:23 AM
Proud Viet Nam Veteran
redoldsman's Avatar
I don't think it will matter at all. Two quarts should be plenty so if you want to buy a name brand, the price for two quarts will not be a big deal. Your could ask Chip if you want an expert opinion because he is an expert for sure.
redoldsman is online now
Old March 11th, 2016, 10:39 AM
Magna86's Avatar
Nope brand doesn't matter Dexron III ATF or higher fluid is all the same. It all meets the specifications to be categorized as that. Only difference is if you went synthetic but still meets the specs.
Magna86 is online now
Old March 12th, 2016, 08:57 AM
top down's Avatar
Thanks for the replies
Talked to Chip @ powersteering.com - he said don't use synthetics in old gear boxes - FYI
top down is offline
rustycragars
December 25th, 2016 06:06 PM
c-towndave
Brakes/Hydraulic Systems
May 16th, 2014 05:05 PM
superstingray77
June 30th, 2011 07:29 AM
HIGHCOMP425
August 5th, 2010 02:35 PM
cfair
June 8th, 2009 12:37 AM
Quick Reply: does brand matter in power steering fluid?
