"Z Code" cars in 1970
#41
I just looked at 4 1970s: 4-door, supreme vert, W30, and R350. No Zs, all have bead (or glue). Let me know if there is something else to check on a no Z car.
BTW, my W30 is blank on broadcast card in the "special area". Sure looks like the Z is a Fisher Body item.
Steve
Steve
#42
Also I see that export option code U18 is for a KM speedo.
Pat
#43
I have owned the car since 1993. When I bought it , it was an unrestored original paint and interior, driver. There was no glue residue or any holes in the bead grove of the dash.
#45
Attached is cutlassbeebe's 1971 Cutlass Supreme Convertible's cowl tag with the Z. So that eliminate anything 1970 only.
I rather doubt it is the bead trim. There would be no reason to code it beyond the model and trim identity.
If that bead is not back for 1971, that would now be officially eliminated.
The build sheet is a final assembly document and basically has nothing to do with Fisher Body designations. The cowl tag is all Fisher body related.
If it is a special or special order interior, what does that mean? So far nobody can find anything "special" in a Z interior.
After speaking with Sam(72XW30) & thinking about the "Z" and that it precludes the interior trim number, I think it could possibly be the ID for
the plastic chrome bead that surrounds the dashpad. I have seen cars with/without this bead.
Anyone have a car without the Z and no dashpad bead?
Just my 2 cents.
Derek(Dick)
Just my 2 cents.
Derek(Dick)
#46
#47
Were these tags made in an automated process or was there human input on every tag? I have no idea if this is even possible in GM but in the trailer indusrty, The tags up till the late 90s were manualy stamped. There would be two to three guys stamping tags all day. Each guy would stamp his ID code in the plate so they could identify who made it if an error was found in the stamping. I know this could not be exactly the deal hear because we only have them with and without a Z. Just wondering if something in this line of thinking could be possible. Maybe the first job of each shift or any internal code of any kind that had nothing to do with the assembly of the car? I would bet we will never know this one but i hope we do.
#48
I am sure this is way off, but could the "Z" have something to do with where the order for the car originated from, or how it was originated? I don't know. Were there any cars put out from the factory that were not ordered from a dealer, or ordered for a buyer ? I really have no clue, just asking.
#51
Okay, question for someone familiar with Canadian safely requirements:
Was there anything required in Canadian cars in 1970 and 1971 that were not required in the US? Like rear belts? Rear center belts?
Looking for body related items.
#54
I had a look at the Canadian Gov't Motor Vehicle Safety Act, specifically in reference to 1970. There is some basic information relating to seating arrangements, but the archived copies go back to 1998 only. Here's the link to the Archive Motor vehicle safety regulations I don't see anything specific that addresses seat belts or harnesses, but it's pretty dry reading. Have a look through though, you might find something of interest. The Act also covers emissions, but I doubt that has anything to do with the quest.
#55
Since the code is associated with the Soft trim level on a particular car, it must be associated with seat, style, color etc.
Possibilities are:
Sound deadner/insulation.
Check seat belt tag info to see if there is any reference.
Headliner
Sunvisors
Anybody ever seen a full build sheet that is assocaited with a Z code car?
Paul
Possibilities are:
Headliner
Sunvisors
Paul
#57
I'd call that a good guess, but I don't think so based on previous searches.
See post #10
https://classicoldsmobile.com/forums...g-mystery.html
And I believe Z49 would be a Canadian "prep" that would not involve a Fisher Body condition.
See post #10
#58
Z49 was: Canadian Warranty, Canadian stickers, Canadian Owners Manual in English or French and Canadian Certification by the CMVSS (Canadian Motor Vehicle Safety Standards) which fell (falls) under the MVSA (Motor Vehicle Safety Act).
#59
Mike (mmurphy77) has a '71 442 with Canadian docs. Z49 on the docs and no Z on the cowl tag.
1. Does anyone have a '70-'71 with Canadian docs that has *both* a Z on the cowl tag and Z49 on the docs? I'm thinking not....? Sam?
2. Does anyone know specifically what the Z49 modifications are?
#60
I *may* (or may not) be on to something here. This all depends on exactly what the the Z49 "Mandatory Canadian Base Equipment Modifications" is. Bear in mind that description is in George Z's words and not the "factory" description.
Kurt,
My cars with the Canadian docs that have the Z do NOT have Z49 on the paperwork at all.
The Z is on the broadcast cards too.
RocketNorth, called George Z about the Z on the cowl tags...hopefully he chimes in!
Cheers,
Sam
#61
Derick, is the Z49 on your Canadian docs?
Tom, do your 2 Z code cars have Z49 on the Canadian docs?
#62
My Canadian documented 71 442 has Z49 on the paper work but no Z on the trimplate, also a bench seat column shift car. Off the top of my head, one of the Cdn. modifications is the oil change spec. sticker on the valve cover, and I'm going from memory, I believe I read the anti-freeze protection is stronger on Canadian destination vehicles for obvious reasons.
#63
#64
FWIW my Canadian sold and documented Cutlass S also has Z49 in the paperwork. No Z on the cowl tag as expected. No console/buckets, just A52 + column
Is the Z code consistently on ALL plants that manufactured the 70/71 A bodies or just a few? It would be handy to validate all the Fisher Works divisions that had Z on the cowl tag.
#65
#66
more info
I have not chimed in on this thread before as I was away from home. I just looked at my 1970 W-31 car that sold new in Calgary AB & obviously Lansing built. Z930 on the cowl tag. There is not a Z49 on my Canadian Documents for that car & I do not have broadcast card for this car.
My Cutlass W-31 does not have the dash trim mentioned earlier not a rear defrost as mentioned by someone else.
Looking at my 72 W-30 sold new in Regina SK it has no Z in front of the 960 on its broadcast cards (I actually found 3 in the car....1 was destroyed beyond keeping but I have the other 2). The Canadian documents for that car show Z49 mandatory Canadian equipment. The car is under cover up on my hoist & I do not have time at the moment to move cars around to bring it down to check the cowl tag.
#67
I do not have Z49 listed on either GM of Canada documentation sheet for my 1970 w30 or w31 (both with Z on the data plate). I do have the broadcast cards for both of these cars and in the box next to the trim code on the top line is a box that says SPCL and in that box is Z. I am guessing that is short for "special". The two boxes are definitely under the "TRIM" header.
Last edited by tomsw31; January 14th, 2014 at 08:06 PM. Reason: Correcting an error in wording
#68
#70
Thank guys. Here is where I'm going with this right now:
It looks like the cowl tag Z and the Z49 are for the same thing, "Mandatory Canadian Base Equipment Modifications".
But it is an either/or. The car has the Z cowl tag *or* the Z49 on the docs, but not both.
The difference? Probably the cowl tag Z cars were ordered to be Canadian sold and the Z49 cars were not ordered to be Canadian, but were eventually sold Canadian. Likewise a Z cowled car could have also been sold in the US.
This also explains why the id on the cowl tag as there would be a good reason for this identifier.
That all said, I don't think we have an definitive answer to what the the "Mandatory Canadian Base Equipment Modifications" are. At this point I don't buy that it is simply "Canadian Warranty, Canadian stickers, Canadian Owners Manual in English or French and Canadian Certification by the CMVSS (Canadian Motor Vehicle Safety Standards) which fell (falls) under the MVSA (Motor Vehicle Safety Act)". That is more like a dealer prep than "base equipment modifications".
The location of the Z on the cowl still may indicate something different in the interior. In post #59, Paul says "Check seat belt tag info to see if there is any reference." To this I add "check the tags to see if there is *any* difference from it's US counterparts.
#71
I concur with Kurt. The possibility of Z car being sold in the states is good! Theory would be car headed to a dealer in Canada for stock and a U.S. dealer had one sold with the same or close to it options it could re-routed for retail.
Or another theory could be a dealer in Canada had one on the lot and same thing, a dealer in the U.S. had one sold and they did a dealer to dealer swap for a similar priced car.
I work for an agriculture/lawn and garden dealer, and we have had the same scenerio for us also.
I would also like to see, other than Canadian intended car, an export car to another country, it's cowl tag for reference.
Attached are again from the SX455 site, are pictures of KPH speedo and a European ID tag. According to the post that this car was for sale in Sweden. No other details.
Pat
Pat
#72
I too concur with Kurt on this Pat.
In the extensive Oldsmobile Division General Motors Corporation list of 1970 Factory Installed Optional Equipment lists in section 96 Canadian Export Option as follows
K05 - Engine Block Heater
P16 - Tire - 4-ply White Wall Nylon
V48 - Maximum Protection - Permanent Anti-Freeze
* Mandatory Option *
Z49 - Mandatory Canadian Base Equipment Modification
Section 97 Knocked-Down Chassis * Export Options *
A39 - Lap Belts Front & Rear - Deluxe *Must Get AS6*
A48 - Lap Belts Front & Rear - Delete *Must Get AS6*
AR1 - Head Restraint - Delete
AS6 - Shoulder Belts Front - Delete
D28 - Mirror Rear View Outside - Delete
L90 - Engine - Export
P38 - Tires - Delete *Five Wheels Only Furnished*
T62 - Battery - Dry Charged
T64 - Battery - Delete
U18 - Speedometer - Export, Kilometer
V78 - Plate - Certificate of Compliance - Delete
ZB2 - Front & Rear Bumper Bars - Unchromed & Unpolished
Section 98 Single Unit Pack Chassis *Export Option*
P32 - Tire - Spare - Delete
T74 - Headlamps - LH Rule of Road - Export
V60 - Tire Pump - Foot - Export
Also in the Special Ordering & Billing Options
X24 - Canada Retail Service *Designated by G.M. of Canada*
Y61 - Export Preparation
Overall the big question is *What is contained in RPO Z49?* Ken (442much) says Z49 entails "Canadian Warranty, Canadian stickers, Canadian Owners Manual in English or French and Canadian Certification by the CMVSS (Canadian Motor Vehicle Safety Standards) which fell (falls) under the MVSA (Motor Vehicle Safety Act)"
#73
Z49
I have a recollection of Z49 being explained to include antifreeze that was capable of a colder freeze point & an additional 0.5 gal of fuel. This was in addition to the Canadian specific stickers & documentation etc already mentioned.
#75
I'm not buying this Canadian theory. My '70 W-30, sold in Alabama just over a week after it was built, has the Z code.
I once ran across a list of many Z codes related to Cameros. I don't have the information here with me. But as I recall there were many Z codes that had nothing to do with export. Maybe I'll dig up the list to further this discussion.
#76
We may be trying to decipher a code where there really is none. It may be that it was someone's six sigma project back in the day.
#77
I'll save you some work:
Z01 : COMFORT AND CONVIENCE GROUP
Z02 : PERFORMANCE PACKAGE, TURBO
Z03 : APPEARANCE PACKAGE, 25 ANNIVERSARY
Z04 : MODEL CONVERSION, 'GTZ' BERETTA
Z05 : CONVENIENCE PKG
Z06 : SPECIAL PERFORMANCE EQUIPMENT PACKAGE
Z07 : PERFORMANCE PACKAGE, AGGRESSIVE SPORT
Z08 : MODEL CONVERSION, CONVERTIBLE
Z09 : MODEL CONVERSION, CAPRICE CLASSIC
Z10 : MODEL CONVERSION, CARGO VAN
Z11 : ALUMINUM NOSED 430HP 427 IMPALA
Z12 : SALES, EXTR FUNCTIONAL & APPEARANCE
Z13 : MODEL CONVERSION, BUICK REGAL GRAN SPORT
Z14 : AIR CONDITIONING (ALL WEATHER) BODY CONVERSION
Z15 : COLLECTOR EDITION
Z16 : AERO-COUPE PACKAGE
Z17 : SPECIAL SUSPENSION/STEERING (MONTE CARLO SS)
Z19 : CONVENIENCE GROUP
Z20 : MONTE CARLO SS 454
Z21 : MODEL CONVERSION GT-BERETTA
Z22 : MODEL CONVERSION, ROADMASTER ITT LMTD
Z23 : INTERIOR DECOR PACKAGE
Z24 : SS 427
Z25 : APPEARANCE PACKAGE, 40 ANNIVERSARY
Z26 : MERCHANDISED PKG, OPEL CONVERSION
Z27 : SUPERSPORT
Z28 : MERCHANDISED PKG, SPECIAL PERFORMANCE
Z29 : VINYL STRIPE
Z34 : MODEL CONVERSION CHEVROLET LUMINA 'Z34'
Z41 : CONVERSION OPTION, CANADIAN PONTIAC
Z47 : CONVERSION OPTION, CANADIAN CHEVROLET
Z49 : EXPORT CANADIAN MODIFICATION MANDATORY BASE EOUIPMENT
Z4Z : INDY PACE CAR REPLICA
Z50 : MODEL CONVERSION, PONTIAC TEMPEST
Z51 : PACKAGE, PERFORMANCE HANDLING
Z52 : MERCHANDISED PKG, SPORT HANDLING
Z53 : CLUSTER, INST, OIL, COOL, TEMP, VOLTS
Z54 : MODEL CONVERSION, CORSICA LTZ
Z55 : SPECIAL VIN PLATE
Z57 : VINYL COATED TRIM
Z5G : IDENTIFICATION, CALLAWAY ORDERS
Z5X : MIRROR PROVISIONS ARABIC LANGUAGE
Z62 : CONVENIENCE PKG, COMFORT & DECOR LEVEL #l
Z65 : PACKAGE, MONTE CARLO SS
Z67 : SPEEDOMETER, DRIVEN GEAR ADAPTER/KEYS
Z6A : REAR WINDOW AND SIDE MIRROR DEFOGGERS
Z70 : CONVERSION NAME PLT, OLDSMOBILE
Z71 : CHASSIS PACKAGE, “OFF-ROAD”
Z72 : TRAILER PPOVISIONS, HITCH, BALL TYPE, L.D.
Z73 : CONVENIENCE PKG INTERIOR TRUCK DECOR
Z74 : APPEARANCE PACKAGE, SONOMA GT
Z75 : CONVERSION NAME PLATE CADILLAC
Z76 : CAMPER PROVISIONS, SPECIAL CHASSIS (COMMERCIAL)
Z79 : APPEAPANCE PACKAGE, TYPHOON
Z7A : MODEL CONVERSION, ASUNA
Z7H : MODEL CONVERSION, CHEVROLET LUMINA
Z7K : MODEL CONVERSION, PONTIAC GRAND PRIX SE
Z7L : MODEL CONVERSION, PONTIAC GRAND PRIX LE
Z7M : MODEL CONVERSION, PONTIAC GRAND PRIX GT
Z7N : MODEL CONVERSION, PONTIAC GRAND PRIX STE
Z7P : MODEL CONVERSION, OLDSMOBILE CUTLASS SUPREME S
Z7Q : MODEL CONVERSION, OLDSM0BILE CUTLASS INTERNATIONAL
Z7R : MODEL CONVERSION, OLDSMOBILE CUTLASS SL
Z7S : MODEL CONVERSION, OLDSMOBILE CUTLASS SUPREME S
Z7T : MODEL CONVERSION, BUICK REGAL CUSTOM
Z7U : MODEL CONVERSION, BUICK REGAL LIMITED
Z81 : CAMPER PROVISIONS, SPECIAL
Z82 : TRAILER PROVISIONS, SPECIAL EQUIPMENT, H.0.
Z83 : CHASSIS PACKAGE, SOLID SMOOTH RIDE
Z85 : CHASSIS PACKAGE, HIGH PAYLOAD FIRM RIDE
Z87 : DELUXE INTERIOR
Z88 : CONVERSION, NAME PLT GMC
Z95 : REGULAR FUEL ENGINE EQUIPMENT
Z8I : CAMPER PROVISIONS, SPECIAL
ZA7 : PACKAGE, VALUE LEADER-CANADIAN
ZAA : TIRE SPARE, COMPACT
ZE5 : IDENTIFICATION, TRIM LEVEL BASE
ZGL : TIRE REAR LT 265/75R16/C BL R/PE ST OOR
ZIN : TIRE SPARE, P205/70R15/N BL, R/PE ST TL AL2 95S
ZJ1 : CUSTOM EXTERIOR
ZJ2 : FLEET INCENTIVE , PHILLIPS PETROLEUM (A/B/C/H/L/W-TRK)
ZJ3 : INTERIOR CONVENIENCE PACKAGE
ZJ5 : EXTERIOR DECOR
ZJ6 : SPECIAL SPORT SEDAN
ZJ7 : WHEEL,SPECIAL HUB CAP 6 TRIM RING
ZJ9 : AUXILIARY LIGHTING GROUP (ALL)
ZK1 : HOOD INSULATION
ZK3 : DELUXE SEAT BELTS & FRONT SHOULDER HARNESS
ZK5 : CONCOURS SEDAN
ZK6 : CONCOURS SPORT COUPE
ZK7 : CONCOURS SPORT COUPE
ZK8 : TIRE PRESSURE LABEL
ZKQ : TIRE PRESSURE DECAL
ZL1 : NOISE CONTROL WITH LESS THAN 8000 LB GVW
ZL2 : SPECIAL HOOD, COWL INDUCTION
ZL3 : SS 396
ZL8 : INVOICE, AUTO FAB, INC.
ZM3 : INVOICE, AUTO FAB INC. ' CAMEO ' EL ' PICKUP
ZM4 : SALES PACKAGE, LUGGAGE CARRIER/RR WINDOW DEFLECTOR
#78
I agree.
Since the broadcast card denotes the Z next to the trim code box, and that box is bracketed on the top with that red sideways parenthesis "border" to the SPCL box, it would make sense it has to be somehow tied to what the trim code denotes.
What does the trim code denote besides bucket or bench and color?
What are the variances to either of those two aspects that might require a line worker to have to do something or install something different than they would normally do if they saw that code without the Z?
Until we put together that master list showing every interior possibility variance to those two aspects and find out what all the Z cars have in common on these possibilities, we probably wont know the meaning of the "Mysterious Z"
#79
Z Codes
Z Code Mystery - Possible Explanation?
I have examined all 5 Olds A body (documented by GM of Canada) vehicle paperwork that I have, Specifically the built codes.
In addition I have twice contacted George Zapara of GM of Canada Historic Services. He could not verify but thought the following is a good possibility:
A. All 1970 to 1971(April ??)Canadian imported "Lansing" cars had a Z in the Fisher trim tag, but no Z49. But did have the V48 "increased engine coolant protectant" option.
B. All (April ??)1971 to 1972 Canadian imported "Lansing" cars had no Z in the Fisher trim tag and no V48. But had Z49 "mandatory canadian base equipment.
Therefore, it seems that in April(?) 1971 the "mandatory canadian base equipment" code was changed from Z to Z49.
Notes:
1. The change was possibly due to a change in Canadian import regulations.
2. As noted on previous threads, some U.S. vehicles may have the Z and/or Z49 because they were destined for export but were exchanged by dealers or the factory.
Please check your applicable built codes & let's get this solved!
Lols.
Derek(Dick)
Notes:
Lols.
Derek(Dick)
#80
Looks like the Buick crowd has run into the same issue! I am not a member so seeing the pic of the cowl tag will not happen, unless I join.
http://www.teambuick.com/forums/show...ck-GS-Trim-Tag
Pat
Pat
