What Temperature gauge is better?
Okay..I'm ready to order some new Gauges to put in my new cluster... I need help on witch one should I order should I get the 120-240 or the 140-280 degree... Would the thermostats play a role on witch one to get it hade a 190 degree and I just replaced it and put a 180 degree.. What's your guys opinion
Yeah.. I prefer mechanical also and I'm leaning towards the 120-240 so if I see the needle all the way up I might still have time to pull over and not do any damage as if I catch it all the way up at 280 it might be too late.. Damage done
Yeah I'm planning on doing that it will be nice to have the dummy light give me a heads up if it starts getting too hot.. Quick question.. For the oil pressure gauge do you know if there is two ports? I don't want to disconnect that dummy light either.. Or do you think I can some how add a "T" fitting and tee off it??
Exactly! Get a 1/8" NPT X 1" (if you can find it) or 2" brass pipe, and a 1/8" NPT "T" fitting.
Put the pipe where the sender goes into the block, then screw on the "T" so the short side is perpendicular to the pipe. Put the gauge in the side of the "T" and the sender in the top side. Works like a charm
Okay cool so I will "T" off of it.. Ok now for the third Gauges I'm going with the vacuum gauge instead of the voltage.. Does anyone know the best place to hook that one up too..
Ah64pilot I got this one on ebay but I think the guy who makes them is a member of CO also and he makes a lot of different styles and sizes you should try to look him up and see his stuff pretty good I can't remember. His name try searching similar trends and see if something comes up ill try to look in a bit .. I'm on my way to the store to get those fittings you game me some good advice on the oil pressure.. Question should I get the vacuum for my vacuum gauge from the intake or the bottom of my card..???
I would get it from the intake manifold because it probably has a 1/8" NPT fitting that goes to the gauge doesn't it? If you go to the carb you'll have to find the manifold vacuum port and even then it won't be a threaded fitting it'll just be a pushed on hose.
Pilot heres the housing seller
https://classicoldsmobile.com/forums...-housings.html
UN = w70442 AN = randy
Al
you can get the vacuum from the carb or manifold, if you use the carb just be sure its manifold vac not ported....if its ported vac you will only get a reading off idle
Al
On the oil pressure gauge,I would not use the plastic tubing that comes with it. Autometer sells an upgrade kit that contains copper tubing instead of the plastic.
If that plastic tubing melts or breaks you will not be happy with oil all over your engine compartment,interior or under your dash.
Thanks w30-dreaming I was just looking and reading on that.. It's like you where reading my mind.. I'm going out on a hunt to the local auto parts store and see if I can find some..Because you are right that plastic one don't look like it's going to handle the jod especially with it going across that hot engine
Yeah copper line is the only way to go found it at autozone 12 dollars not bad.. I think I have everything I need I will install them and try to post pictures of the finish work
Thanks for the complement on the Gauges.. Glad to hear you sold the vert all complete. I hope the new owner brings it back to life.. Mine was a theft recovery and when I bought it my wife went crazy she did not see the potential I told her I could not see a 1972 cutlass supreme convertible go to waste she said I would never bring it back to life.. Now she admits its a very beautiful car and she loves driving it.. Only when I let her..
That's. Just the reflection from the light I hade to use the bright up the inside since of the car it actually matches pretty darn close to the original witch I will never replace I hade some friends over and they asked if that was an original part I was like yeah .. There where chebby guys..
Pilot you have 2 beautiful cars I seen them on you tube.. Mine is on YouTube under vettulose1972.. I been wanting to ask you how did you get that drawing of your two cars on your avatar looks cool sort of a oldschool black and white with color look
#31
Well thank you! I appreciate it...here is the link for the cartoon website. Scott (GAoldsman) had posted some pics in the *New* Good morning thread.
http://www.cartoonize.net/
#33
LMAO! I should try that
BTW, your car is super clean! I love the color! Very nice! I don't have to tell you not to get grease on your seats, oh brother I hate white interior for that! It looks good when it's clean but geez it sucks when it gets dirty.
#34
Don't. Remind me on white seats when my 2 and 4 year old's are jumping all over my seats my wife be like you just going to let them jump all over your car like that.. So I tell her I can always replace the seats but I can never replace. My kids
Nickthefish
January 27th, 2013 10:47 AM
