Trick shift fluid in jetaway. Does it help
Has anyone ever used Trick Shift Tranny Fluid in Jetaway. I was wondering if its better, helps with harder shifts and will help extend the life of the tranny. Thanks, your advise will be appreciated.
Do you really think something out of a bottle is going to fix your transmission whine? Once you start hearing noises it's usually a mechanical problem. A whine is usually the front pump. I understand Trick Shift is very close to Type F so it gives you firmer shifts but maybe not something you could actually feel. If you're fortunate it may be nothing more than a dirty filter/screen in which case I would just put a new one in and and top if off with Type F, Dexron or whatever you'd like. If I'm not mistaken Jetaways used Type A but good luck finding that. I appreciate you want to keep it numbers matching but you may be looking at a tear down of that tranny soon. Don't believe the hype out there. Mechanic in a bottle isn't going to fix it. I just tossed my Jetaway because of it's slipping issues.
It certainly does not slip. The whine when you put it in park, sorry not first. When you put it in gear motors quiets down put inpark and neutral it makes a whine sound. My tranny is fine, and was rebuild by the original owner several years ago.
I run it in all my cars have had good luck with it. Cant say if its better than anyother ? But I had a 700r4 that slipped and didnt want to shift
from 1to 2 when cold and slipped when realy hot and ac on swapped out to trick shift and railed it for another 40,000 mile's
yeahbuddy
January 3rd, 2014 10:08 AM
1965F85_scholten
September 22nd, 2013 07:00 AM
cfair
Brakes/Hydraulic Systems
June 8th, 2009 12:37 AM
