...so identifying help needed.
I finally got home from work and got a chance to dig thru the trunk to see the "spare parts". Grills galore etc. Can I get some help identifying a few of these parts for year specifics please? Thanks on advance.
First 2 pics are for 1972 Cutlass Supreme or Vista Cruiser. plastic with metal trim attached around the outside. Check to see if all mounting tabs ok
Second 2 are 1970 Cutlass / Cutlass S grills - plastic. Also check to see if mounting tabs ok
Last pic is for a 1970 Cutlass - it's called a hood tooth. There should be a part number on the back. Made from metal.
rocket hot rod
January 9th, 2007 06:21 PM
