Rust belt and sodium chloride
For anybody who lives with winter road conditions...Why do we use sodium chloride on the roads? Is it widely used or is it only in the rust belts that it is found?Is this the same stuff that is applied to gravel roads to keep the dust down?
It came to my mind, as a few classics are squeezing in a last ride and got caught out after a nice fresh batch of sodium chloride had been applied to the highway
I've been out when this stuff was put down (I actually saw the truck up ahead!)and had to turn around to avoid it. I don't know how much more harmful it is compared to road salt but I can't imagine it's any better to have splashed up underneath the car.
Sodium chloride is common salt aka table salt.
It is used mixed with fine grit in the UK as a means of preventing road surfaces icing.
It is cheap and relatively harmless in small quantities apart from damaging to the metals used in making cars.
Over use has harmful effects on the local environment, but it is the most cost effective way of keeping roads surfaces ice free.
For those of us with cherished cars the best thing to do is not use the car during winter months.
Roger.
Roger.
Yes, it is the same stuff used on dirt roads for dust control. My dealership lot was at one point in time dirt/sand mix which when dry is very powdery we used it to keep equipment and vehicles dust free for about 3-4 months.
In central Michigan it's mainly a rock or crystal type salt put on our roads. DD usually get an under carriage wash when washing the top side!
Pat
Pat
Pat
Pat
Just trying to understand it....they apply it when temps will be hovering around that freezing mark to attract any moisture that has the potential to freeze making black ice?I know when I apply it to my yard in the summer to keep the dust down when we are working, the soil becomes darker (moister).......
Interesting how things vary around the world.
We don't use salt on the roads in Oregon which is good for our old cars. But the Cascade Mountain Range has lots of cinder cones that are mined for road rock and sanding. The cinder is so abrasive that it takes paint off and even pits the windshield glass.
For dust abatement on gravel roads we usually use Lignin Sulfonate. Its more friendly to the environment. Here's a link taking about it.
http://www.pacificdustcontrol.com/lignin-sulfonate/
Actually it is Calcium chloride or in some cases magnesium chloride that are used to reduce dust on gravel roads
Oh. CaCl and MgCl are entirely different ionic compounds than NaCl.
I was trying to figure out why someone would spray salt on their yard. The Romans used it to prevent anything from growing.
All three of these compounds works by dissolving in water, thus depressing it's freezing point, which has the effect of melting the ice
On your car, all three provide free ions, which facilitate the conduction of micro electric currents, which cause galvanic effects, which cause oxidation (rust).
When i was in seattle they were using some other stuff that doesnt work.
Montreal is supposedly the heaviest salted city in the world. And it's probably a testament to why our roads are so bad.
Sodium chloride, like others have said, IS salt. There's nothing uber special, bonds to your car, more horrible, about one term or the other. Sand is for traction, and salt moves the phase change down some degrees. You can actually salt your cooler and make it run a bit colder. The idea is that, by the time it gets cold enough that salt won't work, it is usually cold enough to not ice in the first place. This, of course, doesn't consider cold snaps, where the ambient is way below freezing, yet the ground is above.
Edit: salt I don't think hurts roads too much. It's the freezing/thawing cycle and the frost heaves that does it.
It is much better for the environment because anything green the salty run off touches will die and for your car because salts facilitate rapid oxidation.
[And as "inhibiting" is the best we can do against rust, I am more than happy that my area has gone salt(s)free.. ]
Here it is, the relevant portion of the NaCl/H2O phase diagram. At any weight percentage up to about 25% NaCl, the freezing temperature of water is lower than pure water. This works to a "maximum" of about -21C or -8F. Colder than that and the salt has no effect.
the last few years they have been adding beet juice and ethanol corn fuel by products to the ice melting salts. nasty stuff
http://articles.chicagotribune.com/2...oad-salt-brine
I have gone to the Detroit auto show (N.A.I.A.S.) before in nasty weather, and everything gets coated in salt, the entire car, windshield, side glass etc. When the forecast is bad, I will take two jugs of windshield washer solvent, because they use so much salt that the washers are on constantly.
Several years ago they experimented with some new chemical in my neck of the woods. The stuff was so corrosive that all the license plates corroded within a couple months. Many cars today (including my own) still sport those rusty plates, nearly obscuring the letters and numbers. I'm still waiting to have a cop pull me over and insist I get new plates. He'll get an earfull from me; the government creates a problem then expects me to pay for their mistake.
That's the way it was when I lived in Omaha, you had to buy a new car every 7 years because the door skins where flapping. All the cars where white in the winter no matter what color they really where.
