Refurbishing a 4 spoke sterring wheel
Does anyone know of a shop that can refurbish a 4 spoke steering wheel and is it possible to change the color of the wrap, looking for a saddle color.
I suppose you could always buy a wheel on the web and have it 'painted' the color you want using rubber polymer paint.
There are colored 4 spoke wheels out there, but they are the smaller 14 1/2 inch wheels, not the 15 1/2 your car likely would have come with.
check this place out it might help you. www.banisters.com Upholstery shop in East Point Ga.
The 14" colored wheels were used on the 1975-79 H-body Starfires. Except for the outer diameter (and the more pronounced faux "stitching") they are identical to the 15" wheels and interchange on the hub.
Keep an eye out on ebay for good steering wheels, i picked one up for under fifty dollars a couple months back, it had all the original grain and a not-cracked horn button to boot.
If you search on ebay for "442 steering wheel" or "cutlass steering wheel" for example, click search and then tier the results for most recently posted, alot of times you can find something that's just been listed, Cheap, for buy it now.
Best of luck,
Tony
Best of luck,
Tony
Thanks for the info, i almost bought a saddle brown wheel off ebay 2 days ago. Glad i missed the end of the auction, I didn't know they came in different sizes but i want the 15 1/2 wheel.
OLDSmobility
October 8th, 2010 05:54 AM
