QuickJack, anyone?
QuickJack, anyone?
Anyone ever used one of these or even heard of it? I saw an ad in Old Cars Magazine and decided to try it. Very impressive. Takes about an hour to go through the initial setup process, installing the fittings and making the connections, installing the hydraulic fluid, bleeding the cylinders, and then the initial run-through. But it works very well, and it's SO much nicer than having to drag a floor jack to all four corners one at a time, jacking it up, putting a jack stand underneath, and repeating. Plus, the car gets higher off the ground. What is shown is the lower height setting, which is probably all I'll need because I mostly want to work on the brakes.
What's also nice is that there is no permanent installation here. When done, the lifts can be rolled off to the side or even hung from wall brackets, which they also sell.
https://www.quickjack.com/
I have had them for about 8 years. 70 Chevelle and 72 Supreme vert. I bought the longer ones, works great and unbelievably secure. BTW I also bought the “pinch weld” blocks for my newer cars….great investment.
I think its a nice option to have, and an affordable one. I'm seeing their popularity rise since I first saw them.
I wish I had them when I was younger....heck, I wish to have them now.
Thanks for sharing your experience with them.
I doubt you would have any problem. The weight distribution on your car is about 54 front 46 rear. That's not much different if it's different at all from a rear-drive car. I think pretty much all cars with the engine in front, front-wheel-drive or not, are slightly heavier on the front end.
Actually, this site says 60/40 front rear, but I saw another site that said 54/46. I'll see if I can find it again.
https://autotalkz.com/cat-oldsmobile...bile-toronado/
But it really shouldn't matter. All cars have designated lift points so they can be raised for servicing. They're shown in the service manual. As long as you use those lift points with the QuickJack, you should be fine. The jack's instruction manual is very specific about making sure you use those lift points. Safety first, always!
https://www.forwardlift.com/mid-rise-lifts/
I would really look closely at one of these over a low rise. Soo much better all the way around..
I've considered these types of lifts, but I have not found them practical for working under the cars. I can't justify the cost to only be able to remove all 4 wheels at the same time, which that requirement isn't necessary very often.
I haven’t invested in a lift of any sort but this jack and crossbeam combination from Harbor Freight (links below) makes getting the car up on stands much easier. The corner pads of the beam also have some grooves that may be useful for pinch weld cars. They aren’t deep enough to take the whole pinch weld but they would keep it snug while lifting.
Of course, the lifts are far nicer.
https://www.harborfreight.com/automotive/jacks-jack-stands/floor-jacks/3-ton-low-profile-super-duty-floor-jack-with-rapid-pump-candy-apple-metallic-red-57589.html
https://www.harborfreight.com/automo...eam-64051.html
Thats why they work well in a body shop. Those guys don't do much under car work. It is still possible to do some work, but obviously there are some substantial limitations. But those limitations are the same with the low rise lift, with the midrise at least the car is at a decent working height..
Thanks. I did wonder about that after I got it up on jack stands, which is the one and only time I’ve ever used it. And from what I understand now there isn’t really a safe place to jack
it from underneath the front or rear, correct?
Not to be a Negative Nelly, but I've been under one and wasn't a fan. They're probably fine as long as you don't have to access the areas blocked by the lifts, like fluid lines, clutch, transmission, etc. Being a large framed guy, it wasn't very fun trying to slither in from the end to access that area. Just something to consider.
I'm 6' 4"; regular 2 post lifts aren't much fun either because I can't stand fully erect under those. I have yet to find a better substitution for jackstands and West Virginia creepers- aka: big pieces of cardboard to slide around on. Plus, you're lying on your back or side and can use your full body for leverage should you need it.
I know they would be handy in the 55 but how would they work on something really low like the z3 BMW or a Miata, I'm looking at 4 inches or less, I have a floor jack that is too tall on the BMW...Tedd
I have one of these https://www.kwik-lift.com/ picked it up for $500 a few years ago it even has a dolly system so you could move it around with the car on it (I have not used them yet)
here is my sons Mustang he had on it I have had the Cutlass my Challenger and 2010 Charger on it with not problems. It does take about 20 minutes to setup.
I am thinking about getting rid of it of a four post lift.
x 2.. I am not 6’4” but over 6’ and almost bought a quickjack, then realized its a pain in the butt slithering in from either end versus the side of the car.. it takes me all of 10-15 minutes tops to jack up individual corners to get all 4 jack stands underneath to lift it up.
It doesn't block much of anything that I need to get to whereas jack stands mounted under the rear axle and under something up front would be directly in the way. With a lie-on-your-back creeper, access to pretty much anything under the car has been easy, even from the front or rear end, in my experience. No slithering needed.
From where I sit, all of this is six of one, half-dozen of the other. Cars cannot be magically levitated into the air. Any lift system blocks something. I like the quickjack because it lifts from the frame rails at exactly the points that the service manual says the car should be lifted from. Plus, it lifts the car evenly, not one corner then another then another then another as putting four separate jack stands into place entails. No stressing of the frame.
Also, in the 2+ decades of owning and working on my car, it has never been lifted corner by corner. Always front crossmember and rear axle. No ill effects doing so and half the lifting…
As another option, single post in-ground lifts are still available. This one was a used take-out when it was put in 30 plus years ago. Still enough room to pull a trans as long as you set it up right and enough height stand up under the car. About the only tricky thing to do is pull a body off a frame. It can be done, but it's a lot easier on a 2 post lift.
This is obviously a permanant fixture in the garage once installed. Even 2 and 4 post lifts can be un-bolted; not this.
