my a/c and heat are reversed
Had some work done on the a/c - heat switch and when I got the car back if I push the temp lever to hot....it puts out cold air...and when pushed to cold...it gives out hot air. (The selector lever in A/C) Would rather not have to go back to where the work was done right now so can anyone tell me if its an easy fix....
Car....what car? I'm guessing you have a 68 Cutlass S & I'm guessing it's the car w/ the buggered up AC/Heater. But, no one here has proven capable of mind reading up to this point. Many have tried, but the migraines are painful.
Well, when I mess up, I do a good job of it.........It is a '68 Cutlass S with the original heat/ac. When I took it in to have the fan switch replaced, I was told it needed two other switches which I bought, and they said they replaced them. Seemed strange since everything worked fine, except the fan switch, when I took it in to them. Anyway, now the heater and ac work, but in reverse order according to the temp lever.
Sorry for the migraines Vintage Chief, but you sure do live in a beautiful place. I don't think a headache could last long if you go outside and enjoy your surroundings.
If I'm not mistaken, the temp lever controls a door in the ductwork that allows air from either the AC evaporator or the heater core to flow into the cabin. Somehow it seems they got that to work backwards from what the factory intended. I'd check out that cable and its connections at both ends.
You need to clarify what "heat and A/C reversed" means. Are you getting hot air on A/C and cold on heat, or does the air blow out the A/C vents in the heat setting and out the heater vents in the A/C setting. These are very different problems. As noted above, the temp is controlled by a cable on the slider. I don't think it's physically possible to reverse the function of that, at least not without a lot of work. It IS possible that the cable is adjusted incorrectly. On the other hand, if the problem is flow from the wrong vents, that is likely caused by incorrectly attached vacuum lines on the control head.
And if you told the shop to do one thing and they replaced additional items that weren't needed, they likely busted stuff when they hamfistedly removed the control head and you should not be paying for that or to fix it twice.
Thanks for trying to answer in spite of my, less than stellar, attempts at explaining.
The heater control valve was not replaced. I had forgotten since it's summer, but there is a shut off valve in the hot water line which I use during the summer. Apparently, the control valve was letting hot water through even though the system was in the ac mode so both heat and ac were both on at the same time. When the shut off valve was installed several years ago, the problem stopped. When cold weather arrives I simply open the shut off valve and the heat operates correctly.Right now the Olds is up on the lift with a car under it, so I can't check the heat function.
I understand exactly what you're saying, however, at this time, my only question is how do I reverse the warm/cold function ? When I slide it to warm....it gives out cold ac air. When I slide it to cold it puts out warm air..........how do I reverse it ? Is it a vacuum issue or a cable issue ?
Remove the vacuum hose from the heater valve on the rear corner of the intake manifold and measure the vacuum at the end of the hose with the temp slider in the WARM position and in the COOL position. This will confirm which way the vacuum signal is working, and that can be used to ensure you have a heater control valve that matches the vehicle's vacuum operation.
capstoneclub
September 16th, 2017 11:37 PM
coppercutlass
January 27th, 2014 09:14 AM
