Leaking carburetor
Leaking carburetor
In need of help with my Holley carburetor, 80457-13, I'm leaking some fuel on the mechanism behind choke, don't know what that's known as.
Leaking very little, doesn't appear to be the carburetor gasket itself.... anybody ever have this problem and what is the solution?
Thanks in advance.
Thanks in advance.
Looks like the throttle plate gasket is weeping. Pull the carb and tighten the phillips head screws on the bottom of the carb. Spray down the carb body with carb cleaner to clean off the dirt and fuel.
Re-install, ,do the float adjustment.
Fire it up and watch the base for seepage. if it seeps, you'll have to replace that base gasket.
Might want to buy a Holley rebuild kit so you have all the gaskets handy
