how to remount a air compressor
how to remount a air compressor on 1983 delta 88 307 V8 i got two bolts one is shorter then the other and one has a nut with it does the shorter one go on top are the bottom and wheres the one with the nut go thanks if you need pics i try take some asap thanks for any help
AIR pump?
or ac COMPRESSOR?
The air pump should have 2 bolts and both should have nuts to be installed on the back side.
Bolt length doesn't really matter on those, as long as they go all the way through.
AC compressor is much more involved, with adjuster bolts, long bolts, and spacers.
or ac COMPRESSOR?
