found a hole in my gas line
Rather then trying 2 patch it I want to change the line. The thing is that the line runs through the frame. Do I have to run it through the frame as well or could i get a braided line n just run it on t he side if the frame??
If you're talking about the main fuel line that goes up over the rear frame rail, that's a world of hurt because the only way to replace it completely is to lift the body. Running a braided or rubber line will get the job done as long as it's secured properly.
If you are talking about a 1971 Cutlass, the only place the fuel line actually runs inside the frame is at the front frame horn, from the firewall to where the line stubs out to the fuel pump. Everywhere else the line is simply bolted to the inside of an open C-channel (or the outside of the box if you have a convertible). There is a section of the line where it runs between the frame and the body, and that part is a PITA to replace when the body is on the frame, but the rest is accessible.
I forgot to have the rear line in place when I put the body on once.
It was not that bad to fix, I just had to remove some of the right rear body mount bolts and drop the frame down off the body about 6 inches at the corner, and tweak the line a little as it went thru.
The frame is very flexible when not secured to the body, so this is easy.
As long as your body mount bolts are removable.
Note that when you install this short piece of hard line that you are supposed to use the hose on each end to protect the hard line from the edges of the frame where it enters and exits. The hose prevents chafing; without it, you will eventually wear a pinhole in the hard line. Ask me how I know. This is all shown in the Assembly Manual.
Del70
November 15th, 2013 02:24 PM
