cutlass vs skylark
cutlass vs skylark
I was wondering if a 72 buick skylark rear window molding will fit a 72 cutlass? They look similar to me. Also what about the rocker panel molding too? I know the steering column will work for sure. Your knowledge is very much appreciated.
Compare:
re: rocker stainless - not chrome.
Buick rocker chrome is 78" long and 2 inches tall. Olds is 79" long and 3" tall. So, no. They aren't interchangeable. Remember also that the Olds rocker stainless is even with the sill plate opening and wraps under the rocker where it's held in place by about 10 screws. Lots of features on 'similar' looking A bodies have enough 'dissimilarity' that they are brand specific. This is one of those cases.
Steering columns from 69-72 Skylark, Chevelle (malibu), GTO, Tempest, T37 and Cutlass are all interchangeable.
Thanks Allan for your input. Carshinebob mentioned that 72 monte carlo is the same as a 72 cutlass supreme?
Last edited by 72cutlassdog; February 8th, 2013 at 07:48 AM. Reason: adding picture
Now if you had a 70-72 Cutlass Town Sedan or CS Holiday Sedan, the rear window trim may be compatible since 4 doors used a completely different rear glass and trim
Hi again.
The back glass from a 70-72 Monte is interchangable with a Cutlass Supreme. So I would think the mldgs. are the same. however maybe not. Chevelle back glass is the same as the skylark. ~BOB
Just to re-direct everyone's thinking here; the OP was asking if the MOLDINGS are the same, NOT the glass. And from what I've been able to gather, neither the rear glass or molding trim from 70-72 Monte Carlo, Skylark or Chevelle 70-72 is compatible with CS 2 door coupe .
halfmoontrail
Cars Wanted
April 26th, 2013 04:10 PM
halfmoontrail
Body work
April 3rd, 2013 04:59 PM
wblaster
April 8th, 2012 07:30 PM
Alex72cutty
February 19th, 2012 03:16 PM
