Best oil for the older car and ZDDP?
#81
I'm still confused!! I'll never look at oil the same as I used to!! It's like steel - until I started working in the steel industry, I never knew that steel was made up of different "ingredients"! I never really thought about it, or had any reason to think about it! To me, steel was steel. Heavy, dirty, and rusts in water! I never looked at a block of steel and wondered hmmmm... is that A-36, P-20, W-2 etc... Then I find out that different steels have different chemical analysis' that they are made of.
Kind of like oils. I'll never remember all this technical stuff, so I'm sure I'll still be asking questions!! I've worked around steel for 14 years now, and what I've learned is.... it's heavy, dirty, and rusts in water, no matter what it's chemical analysis is!! LOL!
From all this, here's some conclusions that I have reached (for myself) in a nutshell:
1. Don't use API Service Rated "SM" or "CJ-4" rated motor oils.
2. Use only API Service Rated "SE-SJ", "CI-4". In a pinch, I would also use "SL" (but has a bit less ZDDP than I would like to see).
#83
Yeah, what BOTH of you said!!
So what oil should a 37 year old Olds 350 engine have in it?; the tires don't get smoked, the car doesn't get raced; pretty much local driven to car shows,cruise ins and work - city driving w/ stop lights, in nice weather; stored in winter with temps in the teens to below 0 at times, while we're praying for spring? Is there only one or two answers to this???
#84
#86
#88
hoo wee this tread has morphed into a monster lol.Who would have thought that there would be this much discussion about oil.My inbox is getting bombarded with this treadhmm now that I think about it i was going to take pic's of the oil i use and the filters.I will have to try to do that along with the many other things going on today.Have fun with your oil
#89
I haven't done much research on this oil so I simply don't know. But from what I see on posts in the motor oil forums, this oil is highly thought of. I'd like to know the API Service Rating of Royal Purple. Do you know what standard it is rated at?
#90
#91
NAPA sells a 15w-40 diesel oil that is CI rated, with the good add pack.
Redline oils have a high ZDDP level as well.
The issue i have with the designer oils is that they are expensive and hard to find.
BTW, I have used diesel oil in all my collector cars since the mid 1980's with no issues at all.
#92
[quote=delmontcrusier;115940]hoo wee this tread has morphed into a monster lol.Who would have thought that there would be this much discussion about oil.
Amazing isn't it!! I would have never guessed myself! It has been interesting though. Thanks Dan, I wrote those names down, and will figure it out!! I do love my car and want whats best for her, bless her old heart! Gotta take care of the engine - especially after Bluevista paints it for me!!! LOL!
#94
That's good to know for the viscosity you mentioned, but does it also apply for the other Rotellas? I have found differences between the weights of the other brands. There's also the variables of high performance, diesel, gas, gas and diesel, so forth and so on.
#95
True, some of the synthetics like AMSOIL are an order online or via a local dealer situation. Also, for example, Brad Penn - I have not seen in my neck of the woods, although I know how to order it, which seems easy enough.
Keep in mind that no matter what oil you choose, they may change overtime to accommodates newer standards and engine technologies.
For the older cars/trucks, racing cars, motorcycles, farm vehicles, other high performance engines, etc. - special attention in the way we make a selection is warranted, IMO.
#96
Amsoil has independent dealers in specific areas around the country, go to their website for more info where they are located. I have not seen their products in the auto stores - but wish they had them there. You can also purchase their products on line, which is a good option except for the S&H expense. But you still save over the long run , needing only one oil/filter change per year or 25000 miles (whichever comes first) on their premium products.
CJ-4 has a running average of phos = 819(ppm) and zinc = 1014(ppm). Below the example target range of 1200-1400(ppm) I am looking for.
There is a study (and API chart) by LN Engineering that gives these API Service running averages (in previous post of this thread) that may be of interest to you.
- CI-4 (on the other hand) is in the target range, having phos = 1150(ppm) and zinc = 1374(ppm)
#97
(I would like to hear from someone who actually has first hand experience with this oil - as I do not, but do like what I read).
#98
Interesting. So I presume you have also been using AMSOIL for years. If so, how do you feel it stacks up (generally) against the others and why?
Ok here's the whole story. I built an S-10 with the 4.3L V-6. I started to AutoX it and spun a bearing my first time out. After that a Mechanic all but insisted that If I was going to do that I was going to run AMSOIL. So I ran their 20W-50 racing oil. Now this is not the same 20W-50 that I run now as that stuff was red like hydraulic fluid with the consistancy of baby oil. I ran that stuff and would simply wait till the oil started to look dirty then change the filter, And the next time it got dirty I would change the oil. So about once a year I would change the oil. Now I was AutoXing and later would road race it. So figure running 20 minutes at a time constant of hard acceleration and braking. I also used this truck as my daily driver in all kinds of weather. There were times I would come out of work late at night with the temps 10 degrees or lower and simply hop in start it and go. No warm up. I put in excess of 12K miles a year. That woulld be all hard miles as I did not treat this truck gently which is kinda how it liked it. So yea you can say I am more than happy with it and it's performance.
#100
Myself I would not touch the Royal Purple because of some experience. I work for asplundh tree service and they had changed the fleet of trucks over to royal Purple because of the claims of the oil and going further between oil changes but they soon started having major problems including 2 motors blowing up ( an expression ) they did replace 2 motors and had overheating issues and breakdowns so they changed all the trucks back over. Now these trucks are used a lot and many of them are pretty old for the buisness. 10 years and the trucks are pretty much toast though they have a couple older than that.
#101
This info is good to know, but it does make me wonder just how old those trucks were when the engines blew and how beat up they may have been from the work runs and multiple drivers.
#103
#104
normally it's one driver resposible for that particular truck , but I know a couple of younger guys that are really hard on them. most of them were big block gas motors with I think the 366 being the motor that was one that "blew". Even when they are sitting still the motor runs the hydraulics so you have to keep the RPM up.
#105
well all this hub bub about oil and I said I was going to post pic's and info on the oil I use so here it is.The first is the normal oil I use for my vehicles and the fram filter I use in them.The second is the oil I use in my olds it is for old or classic vehicles and has slick 50 in it.The oil filter is a baldwin as fram doesn't have the long filter for my car it used to be a 11 they discontinued them.The baldwin is a good quality filter and I don't mind paying the 5 bux to have a decent filter.
#106
Well I have been debating this issue as well and have seen similar threads on other sites with just as many varied opinions...makes it tough. I have been leaning towards Valvoline VR1 or Brad Penn. However, I'm a bit concerned about the lack of detergents in these oils as they are made for high performance use. I do drive my car "aggressively" so high performance oil is fine. I just feel like I'm losing the detergents to gain the zinc???
#107
For myself, I am opting for the higher levels of ZDDP.
#109
#110
#111
Thanks for the links. The same principles should apply as they did 10 years ago. The flat tappet guys still need to be vigilant. Perhaps some of the anti-wear additives have been further reduced. It would be nice if the manufacturers would divulge their additives and the levels.
#112
Oils have changed a lot, for flat tappet cars, not for the better. SN plus in a 30W or less can only have 800 ppm zinc and 700 phosphate. The 40W and up get tricky. Even in SN they can have high ZDDP, it will depend brand to brand. This is why 10W40 and 20W50 VR1 have a SN rating despite having 1300 ZDDP.
#113
Most everything has changed including what I use(Rotella T 15-40) but it still has enough ZDDP that I have no tappet issues. What was good 10 years ago may or may not be the same oil or near the same formula anymore.... Tedd
#118
Best buy at Tractor Supply. I think it is up to T4 these days. 10w30 and 15w40 are ci/ch rated. Straight 30 Rotella no longer contains Zn & Ph in required cam break in levels. It is only rated CJ, which ain’t no good for flat tappets.
