68 442 Convertible Switch/Relay Wiring
I have all 3 bookss for 68, CSM, Fisher Body and Assembly Manual. I cant locate any diagram or schematic for the convertible stuff. Is there a hot wire right out of the fuse block on the engine side to the relay and the orange wire to the top switch off the other side of the relay? Or am I way off base.
Thanks for any help!
Tom,
I'm not sure if this is correct but mine goes from the hot on the horn relay, to the breaker on the firewall, to the switch.
I'm going to upgrade it with relays because 68-69 switches don't last long with the amp draw from the top motor
Mike
edit: Just looked again. Assembly Manual page 12-131
I just re-read the post....
If you haven't figured the wire colors by tonight I'll check for you. I can tell you the wire from the relay to the breaker and breaker to the block is black (yeah, I know, you'd think it was a ground but from the wiring diagram that appears to be correct)
Mike
I emailed you a couple wiring diagrams if you want to go that route
Got that all taken care of. I installed a new breaker switch after work. all is well there. on to the dang mouldings. I need original part numbers for the following if anyone can assist . for the convertible. I need the original part numbers for the clips that hold down chrome around the back of the convertible top. I need the original part number for the 6 plastic door clips. the rest I have. anyone with original part numbers I wuld appreciate the help.
oldzy
September 10th, 2009 05:23 AM
