'66 Toronado steering wheel install
Old May 18th, 2014, 09:58 AM
PurplePan's Avatar
Good morning, I am having difficulty getting shifter detents, neutral safety switch, and steering wheel installed correctly. I'm pretty sure the parts are there and good but I'm thinking there is a trick to getting that hub and detent plate lined up with shifter arm before putting the 3 screws in. Is there a trick, or do I persist and get lucky with holding things in the right place? Thanks ahead of time for any suggestions.
PurplePan is offline
Old May 21st, 2014, 07:57 AM
waterzap's Avatar
I did the steerign wheel on my 67. Was a bit of a struggle getting it all aligned
waterzap is offline
Old May 25th, 2014, 05:39 AM
PurplePan's Avatar
Thanks for the reassurance that it can be difficult to get lined up. I just received the chassis and fisher body maintenance manual on cd so that may give some insight.
PurplePan
May 18th, 2014 09:20 AM
68RocketAction
October 27th, 2013 03:10 AM
Frogge467
April 7th, 2012 08:27 PM
mv213
February 11th, 2012 04:08 PM
four42
January 28th, 2008 11:04 AM
Quick Reply: '66 Toronado steering wheel install
