66 442 radiator
So true. can be timing, carburation, lack of correct skirting around the radiator, bad thermostat, bad fan, no shroud, clogged radiator or engine, it goes on and on. Cross flow radiators like they come with are good. going to an aluminum replacement helps. But, all of the rest needs to be correct also.
Hope this helps
Larry
Hope this helps
Larry
These cars didn't overheat when they were new. Figure out what's changed now and fix that. Don't just swap parts and hope for the best. One thing to consider is that ethanol-laced gasoline causes the engine to run lean, which causes it to run hot.
