54-56 owners unite!
Old November 18th, 2017, 07:29 AM
  #281
Tedd Thompson's Avatar
Originally Posted by setzman
Just got my 55 day after fathers day. Previous owner did a lot of beautiful work to it. I cant get a brake drum.off which has be furious because i wanna go thru the brakes before i hit the road. Also need to fix a gas guage sending unit ground, as well as a trans fluid leak, oil leaks around the oil filter or oil pressure tube, and an oil leak behind the dash. Didnt think that was possible.... Hopefully its on the road stretching its legs by August.
Just a after thought. Your sending unit is grounded with a clamp attached to the gas line which will corrode. This is a poor design by Oldsmobile and should be grounded through the frame like all the other cars in the world. Also if at some time if your car ever had a repair using a rubber hose splice somewhere on to the gas line it will become ungrounded also so check for a splice before you drop the tank.... Tedd
Tedd Thompson is online now
Old November 18th, 2017, 12:13 PM
  #282
classicmuscle442's Avatar
Ted nice looking 55, love the colors.
classicmuscle442 is offline
Old November 18th, 2017, 01:25 PM
  #283
Thanks, she is The Mistress. Takes all my time and all my money.... Lost in the fifties.... Tedd
Old November 18th, 2017, 11:20 PM
  #284
Phantom Phixer
Charlie Jones's Avatar
Originally Posted by pat
hi i have recently had a 1956 olds rocket 324 motor rebuilt for a hot rod i am building ,the problem is i have made a side steer for it and dont have the room for a clutch pedal and would really like to have an auto in it so my wife can drive it also ,i have a 1951 auto for it but would like to bolt up a turbo 350 which is possible but i talked to bendtsens and i explained that i have the inspection cover for the trans but it wont fit over a 176 tooth flywheel and he said any of the three inspection covers will work that they are all the same size,well in a little confused because the one i have will NOT fit .looking for some direction Thanks Pat
Pat,
I assume by inspection cover , you mean the lower bellhousing . The piece that bolts on the block , and the starter mounts to it . Right ?
Olds used at least four of these in the 49 thru 64 period.
The first one was used from 49 thru 53 , and was used with a 145 tooth flywheel .
The second was used from 54 thru 56 (324) , and was used with a 176 tooth flywheel .
The third was used from 57 thru 60 , and was used with a 176 tooth flywheel.
The fourth was used from 61 thru 64 , and was used with a 166 tooth flywheel .
To look at them all together , they look pretty much the same . Except for the place that the starter mounts to . All will bolt onto any 49 thru 64 block .
The best trans conversion (in my opinion) is offered by Ross Racing Engines.
Tony cuts the trans bellhousing off right in front of the pump. And then a special adapter is bolted on the front of the pump and to the block .
http://rossracingengines.com/c/5/old...early-catalog/
Charlie Jones is offline
Old December 10th, 2017, 03:37 AM
  #285
rkauanui's Avatar
Just bought a 56 Super 88! Found this gem sitting in a hanger for the last 14 years!
rkauanui is offline
Old December 10th, 2017, 06:22 AM
  #286
Proud Viet Nam Veteran
redoldsman's Avatar
Welcome. Very nice.
redoldsman is online now
Old January 24th, 2018, 06:37 PM
  #287
Jatorocket's Avatar
I currently have 2 56 Super 88s. One is a mild custom 4 door sedan with a 1960 high comp 394, and the other is an all original Super 88 holiday hardtop.
Jatorocket is offline
Old January 24th, 2018, 08:55 PM
  #288
redoldsman's Avatar
Jatorocket:
I know I have already responded to one of your threads but welcome to this special thread. There are some mightly fine cars featured on here. If you have not started at the beginning and gone all the way through the thread, I suggest you do that so you can see all the cars. Good stuff.
Old February 18th, 2018, 07:45 PM
  #289
abua1969's Avatar
My 56
abua1969 is offline
Old February 19th, 2018, 07:40 AM
  #290
Nice ride, love your color combo. .... Tedd
Old February 19th, 2018, 07:43 AM
  #291
Rocket331's Avatar
Welcome, abua1969. Glad you could join us!
Rocket331 is offline
Old May 20th, 2018, 06:06 AM
  #292
56 BULB's Avatar
I would like to be added to the list of olds owners. I have a 56 rocket 88 4dr sedan bought it as a driver . Have been working on it a bunch sense i got it a year ago. It not a perfect car nor will it ever be with me owning it as we all know it takes very deep pocket to make one a 100 point car . But it all in how we look at the final project & what we are going to do with it . I live in york ,s.c. & hope to post a picture or 2 soon . My best to all of us proud oldsmobile owners.
56 BULB is offline
Old May 20th, 2018, 06:34 AM
  #293
setzman's Avatar
Welcome along!
Welcome to the forum. Also join the forum on Facebook - Classic 54 55 56 Oldsmobile 88. Lots of luck!
Tom
setzman is offline
Old August 19th, 2018, 09:48 AM
  #294
bryson's Avatar
'54 98 4-door. Lives in Utah. Needs work, but damn it's a cool car.
bryson is offline
Old January 30th, 2019, 02:31 PM
  #295
redoldsman's Avatar
Originally Posted by dwl
My 54 Conv.
Why don't you post a picture. I would really like to see it.
Old January 30th, 2019, 04:31 PM
  #296
dwl
dwl's Avatar
go to my profile. yoy should see my car.
dwl is offline
Old February 2nd, 2019, 04:02 PM
  #297
dwl
dwl's Avatar
My 54 at air show
dwl is offline
Old February 2nd, 2019, 04:11 PM
  #298
dwl
dwl's Avatar
My 54
My 54
dwl is offline
Old February 2nd, 2019, 04:53 PM
  #299
redoldsman's Avatar
Very nice. I am not a fan of continental kits but to each his own on that. I see you have the correct paint divider moldings and the end of the hockey stick moldings. Those are very rare and I was fortunate to score a set of those off a parts car. My car was originally sold blue and was sold in May 1954. I believe I read somewhere that Oldsmobile did not start using those until June of 54. Most people change the color under the taillight when they change to two tone paint. Are those original colors?
Old February 2nd, 2019, 05:55 PM
  #300
dwl
dwl's Avatar
Not original color. the blue is called Yatting blue, a porsche color. repainted 6 or 7 years ago. I have 2 more 54 conv. one in primer m issing drivers door and nothing inside. the other one is for parts. really rusty. May get arond to them some day.
Don
dwl is offline
Old February 3rd, 2019, 08:32 AM
  #301
My 54
My 54
Very nice and you say you have a total of three convertibles, that is rare.I really like the color combo also.
Have much trouble traversing gas station entrances with that tail chasing you around.... Tedd
Old February 3rd, 2019, 09:56 AM
  #302
Dennis 55 olds's Avatar
324 ac pully for ballancer
Originally Posted by Rocket331
So, how many '54-'56 owners are on this forum? I know of a few, but there must be more of you out there.
Please sign in!
looking for eitger a 3 groove balancer for 303/324 OR or an add on pulley for ac like used with aftermarket units for 303/324/371/394
Dennis 55 olds is offline
Old February 3rd, 2019, 12:24 PM
  #303
dwl
dwl's Avatar
54 in primer
this is pic of my 54 in primer. do not have pic of the rusty one , it has the complete drive line in it. also have a cont. kit for it.
Yes, you have to enter at an angle to keep from draging.
dwl is offline
Old February 4th, 2019, 12:50 PM
  #304
55 S 88 and 56 98
Please sign in!
i recently bought my daughter a 56 98 4dr Hrd to w/ 56,400 miles on it with NO RUST HOLES....EVER.... and fresh interior and paint for $9000 and I am starting an off frame restoration on a 55 S88 Holiday 4dr Hard top. No rust holes at all but it has surface rust and the car is amazingly ding free. It has been off the road since late 1969. No engine or trans but I have had one from a 55 98 for 28 years or so that runs great to use in it. I have recently found and purchaced every factory option except the power window regulators and power antenna....still looking for these
Old February 4th, 2019, 12:59 PM
  #305
Please sign in!
fortunatly I can do virtually all the work except rechroming. I do engines, transmissions and differentials as well as all body work and interior myself so it just costs me materials..... Doing this 55 is a life long dream that will soon be fullfilled as I grew up in a car that is not only the same make and modle but even tge same colors. You see...dad had 2 texaco stations and used 55 and 56 Oldsmobiles as tow trucks includining draging loaded semi's in to repair. I could not tell ya all how many times I looked over my daddy's shoulder on a trip to see tge speedo at 110 mph and a long neck Mister Brau between his legs....these are GREAT cars
Old February 10th, 2019, 09:15 AM
  #306
55 S 88 and 56 98
Originally Posted by 55/98
Well better late than never. 55 98 checkin in.
how did u get yr picture on here?
Old February 10th, 2019, 09:20 AM
  #307
55 S 88 and 56 98
Originally Posted by DFitz
Add another 55 Holiday, no posts.
Starting an off frame restoration on one just like it....you have a beautiful car
Old February 10th, 2019, 09:24 AM
  #308
55 S 88 and 56 98
Originally Posted by BenJammin
New guy here, but not for long!
1955 Olds Holiday 4-door Sedan Super 88
Right now the interior is a basket case, but soon she will be cruisin.
What did it cost to get the bumpers and hood lower lip rechromed on this beautiful Olds.... Starting a 55 4dr Holiday off frame resto
Old February 10th, 2019, 03:03 PM
  #309
Once upon a time not long ago I was at a at a car show (imagine that) when this older gentleman came up and remarked that he sure liked my car and he bet that I had more in it than what it cost new. Not wanting to insult the older gent on his ignorance of the cost of modern restoring I replied that I had more in the front and rear bumper chrome than the car cost new I don't know if he believed me but it's a true fact. I no longer keep records of what I spend on my cars even after all these years it still shocks me what the bottom line will add up to. This is California prices but about $3300 for the bumpers and assorted small stuff.... Tedd
Old February 12th, 2019, 02:13 PM
  #310
dwl
dwl's Avatar
54 interior
dwl is offline
Old July 16th, 2019, 12:37 AM
  #311
johnlivo's Avatar
Hi, looks like I am the newest addition to the group. 1955 Olds Super 88 4 door sedan.
johnlivo is offline
Old July 16th, 2019, 12:39 AM
  #312
johnlivo's Avatar
Can anyone tell me the correct name for the rubber door stops or bumpers that stop your doors from closing to far, and where I can buy the right ones???
Thanks guys for any help you can offer.
John
johnlivo is offline
Old July 16th, 2019, 04:45 AM
  #313
dwl
dwl's Avatar
Go to fusick automotive products inc.com If they dont have it , you dont need it.
Don
dwl is offline
Old July 16th, 2019, 02:45 PM
  #314
johnlivo's Avatar
Thanks Don!
johnlivo is offline
Old July 16th, 2019, 04:41 PM
  #315
oldsmoboogie's Avatar
I recently picked up a 56 super 88 coupe.
oldsmoboogie is offline
Old July 16th, 2019, 05:13 PM
  #316
Looks like the '56 has nice garage mates, '71 and the '70 Chevelle.
Old July 21st, 2019, 07:09 PM
  #317
klilek's Avatar
1956 98 and S88
Hey everyone, I just picked up a couple cars in the past year. the first I picked up was a very original 1956 4 dr holiday, then a couple weeks ago I picked up a 2dr holiday 98. I am trying to get them both on the road and it is great to have an original as a reference to see what is missing on the 98.
klilek is offline
Old September 2nd, 2019, 03:14 PM
  #318
Gofishgobig's Avatar
‘54 88 2D Sedan
Please sign in!
Just picked this one up, ‘54 88 2D Sedan..... does anyone have knowledge of decoding this ID badge:
Gofishgobig is offline
Old September 2nd, 2019, 03:35 PM
  #319
redoldsman's Avatar
All I can tell you is the 54-3611D is correct for a 54 Super 88 2 door sedan. There were 27,882 Super 88 two door sedans manufactured in 1954. I believe the car was manufactured in California based on the C code on the data plate which would make sense with you being in California.
Old September 2nd, 2019, 06:21 PM
  #320
Rocket331's Avatar
The color/trim codes indicate
it had a Polar White top over a Capri Blue body, just the opposite of mine, and has blue interior trim. Hiding within the patina is a sweet looking Olds.
Quick Reply: 54-56 owners unite!
