40yr old car is falling apart !
#162
#164
Sounds like you need to compile a music video the next time you do a repair and put that tune in there also. Just make sure you bleep out the foul language for posting on this site...
#165
I would have to find a way to speed the film up then , just like on the show . It would be real funny to see someone in fast motion whip a wrench down and it bounces back up and hits them in the face with that music playing too .
#166
I Got It !
Once I had the correct wrench I was done in 5 minutes ! ( pic 1 ) and here's a pic of both belts on ( the camara angle looks funny , but everything is lined up good )
#167
To adjust your mixture:
I'm also going to be messing with this real soon !
lol , ok well that didn't copy and paste very good from my other thread !
- <LI itxtNodeId="161" itxtHarvested="0">Adjust dwell, timing, and valve lash (if you've got solid lifters) <LI itxtNodeId="160" itxtHarvested="0">Adjust idle speed (in Neutral for MT, D for AT) <LI itxtNodeId="159" itxtHarvested="0">Using a vacuum gauge and a tachometer, turn in the mixture screws a little bit at a time (like about ¼ of a turn) until the vacuum and speed start to drop <LI itxtNodeId="158" itxtHarvested="0">Readjust the speed screw to get back to the idle you want <LI itxtNodeId="157" itxtHarvested="0">Keep turning the mixture screws in until you are sure speed and vacuum have JUST started to drop and then readjusting speed - you'll get to a point where if you turn it in any more, you lose speed and vacuum that you can't get back by adjusting the speed screw - that's where you want to be. <LI itxtNodeId="156" itxtHarvested="0">Some instructions will say to turn both screws in an additional ¼ of a turn at this point - basically, just put them where it runs best on the street.
- If you get to a point where you're not sure whether one or the other screws is making a difference, just turn it in bigger arcs and look and listen - like ½ turn clockwise, then ½ turn counterclockwise - ONE of these will make the engine go slower - if it's counterclockwise, you're too rich, if it's clockwise, you're close to the right adjustment.
#168
Just for my reference, who did you get the PS pressure hose (the right styled one) from? I got the generic one I'm not happy with from NAPA and it was pretty expensive. I will prolly go with ILT unless you can tell me a source that has the correct hose for less. thx Bry
Glad to see you got that PS pump and belt on ok. Like you I find that the right tool for the job makes the work go faster and 'friendlier'.
#169
Yup, it had me confoosed. Thought for a second you were trying to be a 'puter'.
#170
This is one that really needs the Benny Hill music added to it - just the right speed!
http://www.youtube.com/watch?v=zGPxx...eature=related
I got a good laugh at it...
#175
Allen , here's some info on that hose you asked about... $19.99 at O'reilly Auto Parts . part # 70273 along with a pic . I tried to send this to you in a PM , but I could never figure out how to add a pic in a PM
#176
Geez - I've never seen the bottoms of my crappers. I feel like I am missing out now...
#177
all joking aside , I'm interested to see if anything is stamped on mine when I dismantle it .
#178
In the years, "AC," though, you are likely to see more of it than ever wanted to.
You don't know fear until you've heard the FLUSH sound followed by a tiny Uh oh , or the sound of tiny feet running out of the bathroom to hide.
#179
Unless you're in the building trades, you never see the bottom side of a toilet bowl during the years "BC" ("Before Children").
#181
#183
It's NOT Over Yet !
Well , I can still hear that noise on start up when car is cold that prompted me to start replacing things . I bought yet ANOTHER belt because the other one stretched and the PS pump was at the end of the adjustment , so now everything is good that way finally , but the noise still haunts me . I thought maybe it was the slight pully misalignment , but if so , why did the last PS pump last 10yrs ? so that's not it . Is it possible that the water pump or the PS pump I just bought is bad ? I thought maybe it could of been the fan itself on the end of the water pump , but not sure ... and I dont think I want to be sticking any long pipe or hose around there while the car is running to listen to see what component is making the racket. I'm gonna add more info to this , but I gotta get back to work brb
#184
Bry, that just sux. You sure it's not the alt? It's in the general same location as the PS and that's where your noise is, right? Try undoing the alt belt and see if the noise goes away..just a thought.
Is it possible to get 2 bad parts in a row? Ummm, gosh yes. Hopefully not though.
#186
Possible , I took both belts off again and NO NOISE , but the minute I put them on again , there it was . I checked the alt again , and it's not that.
Here's the worse part .... I could hear a on & off squeek kinda like Sicky's car was making when the bearing spun , but a lot quieter . I also hear the lower end knock on the passenger side , not real noticable until you have the hood open and your on the passenger side of the car .... This motor is toast . I seems a lot like a healthy motor that someone beat the crap out of , and then they sold it to me . I will have to find a car now that it's spring , and it looks like I'm gonna put that 455 motor in at my moms There is no point and doing anything more to the 350 , it needs to be rebuilt , and since it's not original .... bye bye
Oh I forgot to add that when I got home from work and put it it park and gave her a little rev , it sounded perfectly normal with NO noise .
#187
#188
I still have a few small things to fix besides getting some tires on this thing and then it's time to put an end to this thread ! I will have to start another for the rust repair , and then a thread later on for the 455 swap ( that one will be fun , I can just feel it )
The question is .... do I get a 76 Olds PS pump , because I have to swap all the pulleys , brackets , and accessories from the 350 to the 455 ( no sense having the wrong pump on there ) .... or do I find out the hard way and try to put the 455 in with all the 455 stuff already on it ? I never seemed to of gotten a straight answer why it wouldn't work ... I'll have to go back and review , but remember this was a 455 from a 68 Toro so I know about the oil filter adaptor , and the switching of the starter from the passenger side to the driver side , other then that everything else should bolt right up including the 350 manifolds and 350 motor mounts/frame mounts . I would also need a radiator short term .
OK , I'll stop until I get to that bump in the road !
#189
The Fan Perhaps ?
I just read and commented on another thread about the fan clutch going bad , and mine spins freely with the belts on or off ... If my memory serves me right , It's suppose to move by hand but not literally spin , right ? even if it is just the fan itself that's causing the noise , I'm still gonna shoot for the 455 swap
#190
Also try to shake the fan up and down to see if the clutch bearing is bad.
#191
#192
cool , I'm gonna leave it for now .... I can only find a used P215-70-R14 tire , the ones I had were P225 I beleive , so I may have to spring for new ones. Then It's onto the rust deal as soon as I get a can of POR-15
#193
The worse news I could get
I'm not sure if I'll be back ! I just received news from my wife that I'm in the way of her being her own person , so I guess I have other things to worry about now. I let you all know when my junk is for sale !!!
Later on in the evening .... I apologize , but I may have to go away for awhile until I can get things in order. I also didn't mean to bring this here ... It's been a tough road to say the least .
#194
Now that really bites! I feel for ya, cause I have been in that situation too many times (though never married but almost). It took lots of willpower but finally gave up on relationships. It was all too much to handle.
On the plus side, Lady's resto helped me concentrate on a good thing and helped me get over the last failure. The friendships I made over here helped a lot also. I joined here right after that event.
I hope you guys can work something out if it was meant to be. But if not, I hope things get better for ya. Hope you still hang out over here with us!
#195
Wow, Bry - I'm sorry to hear that.
I kinda thought that the whole point of marriage was to keep both parties from being "their own persons." That's why it's so hard to hang out with your single friends after you get married.
I don't recall whether you had mentioned having kids - if not, this is probably for the best by a wide margin - you want these things to come up and get sorted out as early as possible.
Under the circumstances, if this progresses to the "sleeping in the yard shed" stage, you might be able to find a member near you who would be willing to help store or move your Olds stuff until things settle down...
And don't get rid of the car - at least it works, and doesn't treat you too badly .
#196
OK, I'll be the designated jerk this morning to post this.
TOP 30 REASONS WHY CARS ARE BETTER THAN WOMEN.
1. You can look at pictures of nice cars all you want to and not feel like
a pervert.
2. You can lust after another car and your current car won't care.
3. You can hang any kind of car picture in your dorm room and not get in
trouble.
4. Women can't go 200 miles per hour.
5. A woman can't carry four of your friends on a road trip.
6. You can replace your car any time you want and not feel bad.
7. A car doesn't have girlfriend cars that will talk about you and tell
her that you are not good for her.
8. You can't install sub-woofers in a woman.
9. You can rub and wax a car in your driveway and not get arrested.
10. Car's don't care if you leave them in the garage overnight.
11. Cars don't care if you go on a trip for three weeks and don't call
them.
12. I f you are nice enough, your friend will almost always let you borrow
their car.
13. You can get together with friends and compare cars and not sound like
pigs.
14. Car's don't get mad at you for no reason every 28 days.
15. You can have two cars at once and they won't be jealous of each other.
16. Cars don't have relatives that you have to be nice to.
17. You can always test drive a car before making a commitment.
18. Car's come with an owners manual.
19. Your car does not care if you get fat and walk around with no shirt
on.
20. You have 100% complete control over the direction of that car at all
times.
21. You can stare at nice cars in a parking lot and your car won't care.
22. You can't put a bumper sticker that says "How's my driving? Dial
1-800- EAT-S*IT!" on a woman.
23. Car's could not care less about commitment.
24. You don't mind too much if your friends always want a ride in your
car.
25. If your car is being repaired, you can usually get a loaner car.
26. If you are 21, you can legally rent a car. 'Nuff said..
27. You can complain about how ratty your car looks and people think it's
funny.
28. You can sell your car to a complete stranger and nobody will get mad
at you.
29. A woman does not have keyless entry or remote ignition
30. and finally. There are 50 year old cars that still look good.
#198
a pervert.
trouble.
them.
their car.
pigs.
on.
times.
car.
funny.
at you.
a pervert.
trouble.
them.
their car.
pigs.
on.
times.
car.
funny.
at you.
#199
