2000 Intrigue front bearing/hub stuck!!!!
Replacing passenger side front hub/bearing assembly on a 2000 Intrigue. I can not remove the hub assembly from the axle shaft. I have tried beating, heating with a small propane torch, gear puller, soaked with pb blaster... It has not moved. Any suggestions?
Thanks,
Don W
Thanks,
Don W
In all honesty the axle for that side of the car should be fairly cheap break lower ball joint lose pull axle and hub off in one replace axle with new wheel bearing cut axle shaft where it goes through knuckle. other wise get hotter torch, heat hub assembly up more with nut on axle shaft beat hard with bfh.. with 3 bolts still tight in wheel bearing loosen axle nut a bit heat with torch and beat on it. it should break loose. are you in a salt state?
marxjunk
February 24th, 2015 06:45 PM
scooter123
January 20th, 2014 09:53 AM
Flye
Drivetrain/Differentials
July 30th, 2009 10:24 AM
